KC868-H32B blinds motor control and connect - Printable Version +- Smart Home Automation Forum (https://www.kincony.com/forum) +-- Forum: Technical Support (https://www.kincony.com/forum/forumdisplay.php?fid=1) +--- Forum: KC868-HxB series Smart Controller (https://www.kincony.com/forum/forumdisplay.php?fid=2) +--- Thread: KC868-H32B blinds motor control and connect (/showthread.php?tid=2011) |
RE: KC868-H32B blinds motor control and connect - JoeM - 12-22-2022 (12-22-2022, 01:02 AM)admin Wrote: usually two relay work with one motor, now H32BS the newest firmware have added "interlock" option for motor, that is useful for motor and protect motor. make sure you can update to firmware v1.50SP. here is download link: https://www.kincony.com/forum/showthread.php?tid=2455 ok. can you send link for instructions how to update? First time doing this
RE: KC868-H32B blinds motor control and connect - admin - 12-22-2022 https://youtu.be/LLIJe9VTVq8 RE: KC868-H32B blinds motor control and connect - JoeM - 01-20-2023 (12-22-2022, 07:06 AM)JoeM Wrote:(12-22-2022, 01:02 AM)admin Wrote: usually two relay work with one motor, now H32BS the newest firmware have added "interlock" option for motor, that is useful for motor and protect motor. make sure you can update to firmware v1.50SP. here is download link: https://www.kincony.com/forum/showthread.php?tid=2455 is there any other way instead of using RS485-USB cable? RE: KC868-H32B blinds motor control and connect - admin - 01-20-2023 only use by USB-RS232 cable, not RS485. RE: KC868-H32B blinds motor control and connect - JoeM - 03-13-2023 (01-20-2023, 11:35 AM)admin Wrote: only use by USB-RS232 cable, not RS485. Hello, I have difficulties installing USB-RS232, tried on several computers and didn't manage to install. Is there any other way? I have Somfy WT protect motors. Can motors be damaged if software on HS32BS not updated? RE: KC868-H32B blinds motor control and connect - admin - 03-13-2023 when update firmware will not control your relay output ON/OFF. RE: KC868-H32B blinds motor control and connect - JoeM - 03-14-2023 (03-13-2023, 11:00 AM)admin Wrote: when update firmware will not control your relay output ON/OFF. Can you please clarify more detail? You mean automatical control will not work? If I use manual switch than it should work normally? RE: KC868-H32B blinds motor control and connect - admin - 03-14-2023 my means: during you update your firmware. controller's relay will not change state. I have Somfy WT protect motors. Can motors be damaged if software on HS32BS not updated? why must update your firmware? current version also can use. i don't know what you want to do with update firmware. RE: KC868-H32B blinds motor control and connect - JoeM - 03-14-2023 (03-14-2023, 08:22 AM)admin Wrote: my means: during you update your firmware. controller's relay will not change state. Ok, understand what you mean. Thanks for fast response. I wanted to update firmware of HS32BS because it was advise by Kincony to update so the controller can work with blinds. Did I understand wrong? RE: KC868-H32B blinds motor control and connect - admin - 03-14-2023 ok, if you want use "interlock" function, you can update. |
