KC868-A2 ESP32 I/O pin define - Printable Version
+--- Forum: KC868-A2 (https://www.kincony.com/forum/forumdisplay.php?fid=43)
+--- Thread: KC868-A2 ESP32 I/O pin define (/showthread.php?tid=2691)
Pages: 1 2
RE: KC868-A2 ESP32 I/O pin define - admin - 12-22-2024
take a photo of your A4S PCB. i want to see PCB version.
RE: KC868-A2 ESP32 I/O pin define - taalaibek - 12-22-2024
(12-22-2024, 07:40 AM)admin Wrote: take a photo of your A4S PCB. i want to see PCB version.
GPIO13 and GPIO15. here is diagram
RE: KC868-A2 ESP32 I/O pin define - piratzaskoku - 09-01-2025
To use these GPIOs, do I need to call any library?
RE: KC868-A2 ESP32 I/O pin define - admin - 09-02-2025
ESP32 GPIO you can use it directly, without install library.
RE: KC868-A2 ESP32 I/O pin define - Vitaly8209 - 12-09-2025
(03-16-2023, 05:31 AM)admin Wrote: Relay1:15
Relay2:2
DS18B20/DHT11/DHT21/LED strip -1: 33
DS18B20/DHT11/DHT21/LED strip -2: 14
#define ETH_ADDR        0
#define ETH_POWER_PIN  -1
#define ETH_MDC_PIN    23
#define ETH_MDIO_PIN  18
RS485:
RXD:35
TXD:32
GSM:
RXD:34
TXD:13
DI1:36
DI2:39
IIC BUS:
SDA:4
SCL:16
board KC868-A2-V2.5 -  all the same?
RE: KC868-A2 ESP32 I/O pin define - admin - 12-09-2025
just the GSM pin define should be:
tx_pin: GPIO5
rx_pin: GPIO13
