KC868-COL - Printable Version +- Smart Home Automation Forum (https://www.kincony.com/forum) +-- Forum: Technical Support (https://www.kincony.com/forum/forumdisplay.php?fid=1) +--- Forum: KC868-HxB series Smart Controller (https://www.kincony.com/forum/forumdisplay.php?fid=2) +--- Thread: KC868-COL (/showthread.php?tid=27) Pages:
1
2
RE: KC868-COL - admin - 11-20-2020 2. my means is digital input for KC868-COL . your photo's input is relay board's , just read the relay board's DI sensor input state. RE: KC868-COL - Nebojsa - 11-20-2020 Problems appear what you not issue correct and detail user manual, where each item on screens detail explain what mean and how use. Please accept my apologize, but issuing videos on YouTube can not replace manuals. Please try issue professional technical manual. I suppose you try make Kincony more popular and increase sales, you will do it just if make it. No one like ask support if everything explain in manuals. Hundreds short Video can be just as additional support but not basical. RE: KC868-COL - Nebojsa - 11-20-2020 (11-20-2020, 01:02 AM)admin Wrote: thanks for your suggestion. 2. There are two way to see input state. one is "read always" button for search. another is auto report, that mean you can not to search alway, when state changed, will auto change the ico state, this way is more efficient. I select Auto Report On or select Auto Report Off Not change Input Relays Status, untip press Read. I wish work it automatic in real time, If input Closed need show status and oposite. Maybe I doing some wrong. I use COL software what you here declared. (11-20-2020, 01:02 AM)admin Wrote: thanks for your suggestion. 2. There are two way to see input state. one is "read always" button for search. another is auto report, that mean you can not to search alway, when state changed, will auto change the ico state, this way is more efficient. I select Auto Report On or select Auto Report Off Not change Input Relays Status, untip press Read. I wish work it automatic in real time, If input Closed need show status and oposite. Maybe I doing some wrong. I use COL software what you here declared. |
