KC868-A8 Ethernet Problem - Printable Version +- Smart Home Automation Forum (https://www.kincony.com/forum) +-- Forum: Technical Support (https://www.kincony.com/forum/forumdisplay.php?fid=20) +--- Forum: KC868-A8 (https://www.kincony.com/forum/forumdisplay.php?fid=23) +--- Thread: KC868-A8 Ethernet Problem (/showthread.php?tid=3269) Pages:
1
2
RE: KC868-A8 Ethernet Problem - msinfo - 09-26-2023 (09-25-2023, 10:27 PM)admin Wrote: can you try to re soldering the LAN8720A chip? which store you have bought A8 board from? Do i try to re solder the same chip or do i get a new one ? I got it from Aliexpress. RE: KC868-A8 Ethernet Problem - admin - 09-26-2023 you can try to re solder it, if also have problem, contact with your aliexpress seller, re send you a new KC868-A8 PCB. RE: KC868-A8 Ethernet Problem - msinfo - 09-26-2023 (09-26-2023, 10:49 AM)admin Wrote: you can try to re solder it, if also have problem, contact with your aliexpress seller, re send you a new KC868-A8 PCB. Ok, thank you. RE: KC868-A8 Ethernet Problem - admin - 09-26-2023 you are welcome. RE: KC868-A8 Ethernet Problem - Namil Heo - 09-30-2024 (09-16-2023, 03:32 PM)msinfo Wrote: Hello, i have a KC868-A8 Board connected with ethernet cable but the port suddenly stopped working.[quote pid="8861" dateline="1694878346"] ethernet: #define ETH_ADDR 0 #define ETH_POWER_PIN -1 #define ETH_MDC_PIN 23 #define ETH_MDIO_PIN 18 #define ETH_TYPE ETH_PHY_LAN8720 #define ETH_CLK_MODE ETH_CLOCK_GPIO17_OUT manual_ip: static_ip: 192.168.0.144 gateway: 192.168.0.254 subnet: 255.255.255.0 [/quote] RE: KC868-A8 Ethernet Problem - Namil Heo - 09-30-2024 #define ETH_ADDR 0 #define ETH_POWER_PIN -1 #define ETH_MDC_PIN 23 #define ETH_MDIO_PIN 18 #define ETH_TYPE ETH_PHY_LAN8720 #define ETH_CLK_MODE ETH_CLOCK_GPIO17_OUT IPAddress local_ip(192, 168, 0, 144); IPAddress gateway(192, 168, 0, 254); IPAddress subnet(255, 255, 255, 0); Hello, i have a KC868-A8 Board connected with ethernet cable but the port suddenly stopped working. |
