KinCony Cloud Server will stop service in 2025 upgrade to TUYA app - Printable Version +- Smart Home Automation Forum (https://www.kincony.com/forum) +-- Forum: Technical Support (https://www.kincony.com/forum/forumdisplay.php?fid=1) +--- Forum: News (https://www.kincony.com/forum/forumdisplay.php?fid=5) +--- Thread: KinCony Cloud Server will stop service in 2025 upgrade to TUYA app (/showthread.php?tid=5437) Pages:
1
2
RE: KinCony Cloud Server will stop service in 2025 upgrade to TUYA app - athxp - 04-15-2024 I would therefore need 2 Tuya adapters. Is it not possible to make them work via the h32L LAN without using wifi? RE: KinCony Cloud Server will stop service in 2025 upgrade to TUYA app - admin - 04-15-2024 how many relay controller you have, so that use how many tuya adapter. H32L use ethernet, tuya adapter use wifi connect to your router. RE: KinCony Cloud Server will stop service in 2025 upgrade to TUYA app - athxp - 04-16-2024 I have two h32L (more in COL). I'd like to use wired only for best performance RE: KinCony Cloud Server will stop service in 2025 upgrade to TUYA app - admin - 04-16-2024 it's ok, use by RS232 cable. RE: KinCony Cloud Server will stop service in 2025 upgrade to TUYA app - athxp - 04-16-2024 so can I split the rs232 cable? I already use the long range input terminal block RE: KinCony Cloud Server will stop service in 2025 upgrade to TUYA app - admin - 04-16-2024 if you want use switch terminal board, it already used RS232 port, so tuya adapter can't use RS232, i have said, control by network for tuya adapter is ok. |
