KCS firmware - Printable Version
+--- Thread: KCS firmware (/showthread.php?tid=6634)
Pages: 1 2
RE: KCS firmware - admin - 09-18-2024
(09-18-2024, 07:55 PM)remiasz Wrote: Where to connect HC-SR04? It works on 5V and HT ports on 3V.
Maybe it's better to use 433M interface? 433M_T signal as trigger and DATA_R as echo. There is also 5V power supply on connector P2.
How to set PIN parameter?
Yes, HC-SR04 sensor output signal level is 5V or 0V. you can connect with 433MHz receiver data pin on PCB, that is 5v level.
RE: KCS firmware - xxpeta - 10-06-2024
one suggestion to improve your KCS firmware for KS868-AI:
add a possibility to send status of all inputs via UDP by defined time in setup, i.e. every 5 minutes.
It will help with integration to Loxone system, because now is sent only once by change and may happen, that UDP packet will be lost.
Thanks in advance.
Petr
RE: KCS firmware - admin - 10-07-2024
wheher Loxone can decode message with all input state together? or only can update by single channel?
now whether input state changed , will auto upload message. because if alway loop, message will cost resource.
RE: KCS firmware - xxpeta - 10-07-2024
(10-07-2024, 01:07 AM)admin Wrote: wheher Loxone can decode message with all input state together? or only can update by single channel?
Loxone can parse the messageĀ  (RELAY-INPUT-255,1,\v ) but it should look like this to be able use the same virtual input:
RELAY-INPUT-255,1,1|RELAY-INPUT-255,2,0|RELAY-INPUT-255,3,1...
Or you can just repeat all single messages in loop. If the repeat interval will be in minutes, there will be small costs of resources.
ok, understand.
