Troubles UART - Printable Version
+--- Thread: Troubles UART (/showthread.php?tid=8269)
Pages: 1 2
RE: Troubles UART - admin - 06-30-2025
you should use PC connect to KC868-A6 wifi hotspan firstly. please see KCS v2 onlie guide firstly, how to set wifi.
Note: if you want config only by WiFi, when power on, your computer will find the “AP” hotspot, WiFi signal named “board name” + “ID”.
[Image: AP.png]
Let your computer connect to the “AP”, it’s without password, after you connected, just use http://192.168.4.1 to login by webpage.
If you can’t see the “AP”, you can “hold on” board’s function button (ESP32 GPIO0) >10 seconds, then board will be set to factory, default state is “AP”.
[Image: web-login.png]
RE: Troubles UART - ksarz - 07-02-2025
(06-27-2025, 08:55 AM)admin Wrote: 1. do you understand me? change network adapter option.
after you connect pc with kc868-a6 board by wifi hotspot, set STA mode, then check ip by scan device tool. please see online guide firstly: https://www.kincony.com/esp32-kcsv2-firmware.html
2. A and B use by RS485, not serial port.
RS485 RXD: 14
RS485 TXD: 27
extend serial port use by GPIO12,GPIO13 on pcb
Sorry,I do not understand it.
Pin "A" on the board is the  RS485 RXD: 14  and Pin "B" is the  RS485 TXD: 27.
Yes or NOT???
RE: Troubles UART - admin - 07-02-2025
please see KC868-A6 schematic: https://www.kincony.com/download/KC868-A6-schematic.pdf
