how to enable the USB ports on Raspberry Pi CM4 - Printable Version +- Smart Home Automation Forum (https://www.kincony.com/forum) +-- Forum: Technical Support (https://www.kincony.com/forum/forumdisplay.php?fid=1) +--- Forum: KC868-Server Raspberry Pi4 local server (https://www.kincony.com/forum/forumdisplay.php?fid=17) +--- Thread: how to enable the USB ports on Raspberry Pi CM4 (/showthread.php?tid=1980) |
RE: how to enable the USB ports on Raspberry Pi CM4 - admin - 09-05-2023 if you don't know how to do, you can see our video tour on youtube channel. installed driver on PC, when connect USB-C cable to your computer, your computer windows will have a new Disk, just open disk , you will see config.txt. as same as a USB-disk. RE: how to enable the USB ports on Raspberry Pi CM4 - fra6767ita - 09-05-2023 Hello, very good, now usb port are ok thank you for you assistance amd patience..you are welcome thanks RE: how to enable the USB ports on Raspberry Pi CM4 - admin - 09-05-2023 ok |
