KC868-H32B blinds motor control and connect - Printable Version +- Smart Home Automation Forum (https://www.kincony.com/forum) +-- Forum: Technical Support (https://www.kincony.com/forum/forumdisplay.php?fid=1) +--- Forum: KC868-HxB series Smart Controller (https://www.kincony.com/forum/forumdisplay.php?fid=2) +--- Thread: KC868-H32B blinds motor control and connect (/showthread.php?tid=2011) |
RE: KC868-H32B blinds motor control and connect - JoeM - 03-14-2023 (03-14-2023, 10:27 AM)admin Wrote: ok, if you want use "interlock" function, you can update. ok, great. you mean that "interlock" function is needed to prevent current go through up and down relay at the same time? RE: KC868-H32B blinds motor control and connect - admin - 03-14-2023 "interlock" function will let some relay never ON at the same time. (user can preset by user which relay work with "interlock") RE: KC868-H32B blinds motor control and connect - JoeM - 08-08-2023 (03-14-2023, 10:27 AM)admin Wrote: ok, if you want use "interlock" function, you can update. Hello, Unfortunately, I didin't manage to update. The problem I have is with manual switching blinds motor. Currently I have to press 2 times UP (first time to turn ON relay for UP and second time to turn OFF relay for UP), thank I can press DOWN to go go down.. How can I adjust my HS32BS and E16 to have functionality of "motor mode" as described in video: https://www.kincony.com/%E3%80%90iot-training-lesson-beginners-03%E3%80%91how-to-let-your-motor-become-smart.html. Furthermore, in case of "motor mode", how do I stop blinds, for example, a half way UP or DOWN. RE: KC868-H32B blinds motor control and connect - admin - 08-08-2023 H32BS have "interlock" function , you can set which two channel relay of your blind motor. E16S also have "interlock" function when you download "KCS" firmware. |
