A16 flash problem - Printable Version
+--- Thread: A16 flash problem (/showthread.php?tid=3045)
Pages: 1 2 3
RE: A16 flash problem - admin - 11-25-2023
just download KCS firmware , then directly to use board, why download arduino code again?
RE: A16 flash problem - zeltini1401 - 11-26-2023
Because the Lan wire is not identified. I think if I put another sketch, the lan wire will be identified. I started from the beginning. I loaded only the KCS_KC868_A16_V2.1.9.bin file according to the instructions. There is a wifi network. Lan cable shows as "Unidentified Network".
I also changed the IP address in the Lan properties to: 192.168.1.200
255.255.255.0 but no change.
RE: A16 flash problem - admin - 11-26-2023
do you let A16 connect to your router by network cable? or you use network cable connect A16 with your computer directly?
RE: A16 flash problem - zeltini1401 - 11-27-2023
(11-26-2023, 11:21 AM)admin Wrote: do you let A16 connect to your router by network cable? or you use network cable connect A16 with your computer directly?
The laptop is connected to the board with a usb to lan adapter.
RE: A16 flash problem - admin - 11-27-2023
no, you should let your A16 and computer connect to same router.
RE: A16 flash problem - zeltini1401 - 11-29-2023
(11-27-2023, 10:45 AM)admin Wrote: no, you should let your A16 and computer connect to same router.
The connection to the Lan wire was successful through the router. Thank you.
I want to solder wires to the switches of the Hardi hc2500 control panel and connect them to the relays of this board.
How can I wire together this board with AgIO v5.7 to make the relays work.
RE: A16 flash problem - admin - 11-29-2023
sorry, i don't know your hc2500 control panel how it works. maybe you need confirm with the supplier, how to connect a extend relay board, whether have some interface for integration.
