Lesson27- KC868-A8 integrate home assistant by ESPHome demo and http command - Printable Version +- Smart Home Automation Forum (https://www.kincony.com/forum) +-- Forum: Technical Support (https://www.kincony.com/forum/forumdisplay.php?fid=1) +--- Forum: KC868-A series and Uair Smart Controller (https://www.kincony.com/forum/forumdisplay.php?fid=6) +--- Thread: Lesson27- KC868-A8 integrate home assistant by ESPHome demo and http command (/showthread.php?tid=1008) |
Lesson27- KC868-A8 integrate home assistant by ESPHome demo and http command - admin - 11-02-2021 ESPHome configure for KC868-A8: function list: 1. 8 relay output 2. 8 switch input trigger relay output by on_press action 3. monitor 2 channel analog input for DC 4. TEMP-1 port: 2 channel DS18B20 temperature sensor use by 1 ports, actually, you can connect multi DS18B20 by one wire. 5. TEMP-4 port: WS2812B LED strip for 1 meter (30 LEDs) 6. network by Ethernet cable ----------------------------------------------------------------------------------------------------- esphome: name: kc868-a8 platform: ESP32 board: esp32dev # Enable logging logger: # Enable Home Assistant API api: ota: password: "bfb55afbf347b27a4bda0a1d36ee994f" web_server: port: 80 # Example configuration entry for ESP32 i2c: sda: 4 scl: 5 scan: true id: bus_a # Example configuration entry ethernet: type: LAN8720 mdc_pin: GPIO23 mdio_pin: GPIO18 clk_mode: GPIO17_OUT phy_addr: 0 # Optional manual IP manual_ip: static_ip: 192.168.1.199 gateway: 192.168.1.1 subnet: 255.255.255.0 # Example configuration entry pcf8574: - id: 'pcf8574_hub_output' address: 0x24 - id: 'pcf8574_hub_input' address: 0x22 # Individual outputs switch: - platform: gpio name: "switch1" id: switch1 pin: pcf8574: pcf8574_hub_output # Use pin number 0 number: 0 # One of INPUT or OUTPUT mode: OUTPUT inverted: true - platform: gpio name: "switch2" id: switch2 pin: pcf8574: pcf8574_hub_output # Use pin number 0 number: 1 # One of INPUT or OUTPUT mode: OUTPUT inverted: true - platform: gpio name: "switch3" id: switch3 pin: pcf8574: pcf8574_hub_output # Use pin number 0 number: 2 # One of INPUT or OUTPUT mode: OUTPUT inverted: true - platform: gpio name: "switch4" id: switch4 pin: pcf8574: pcf8574_hub_output # Use pin number 0 number: 3 # One of INPUT or OUTPUT mode: OUTPUT inverted: true - platform: gpio name: "switch5" id: switch5 pin: pcf8574: pcf8574_hub_output # Use pin number 0 number: 4 # One of INPUT or OUTPUT mode: OUTPUT inverted: true - platform: gpio name: "switch6" id: switch6 pin: pcf8574: pcf8574_hub_output # Use pin number 0 number: 5 # One of INPUT or OUTPUT mode: OUTPUT inverted: true - platform: gpio name: "switch7" id: switch7 pin: pcf8574: pcf8574_hub_output # Use pin number 0 number: 6 # One of INPUT or OUTPUT mode: OUTPUT inverted: true - platform: gpio name: "switch8" id: switch8 pin: pcf8574: pcf8574_hub_output # Use pin number 0 number: 7 # One of INPUT or OUTPUT mode: OUTPUT inverted: true binary_sensor: - platform: gpio name: "input1" pin: pcf8574: pcf8574_hub_input # Use pin number 0 number: 0 # One of INPUT or OUTPUT mode: INPUT inverted: false on_press: then: - switch.toggle: switch1 - platform: gpio name: "input2" pin: pcf8574: pcf8574_hub_input # Use pin number 0 number: 1 # One of INPUT or OUTPUT mode: INPUT inverted: false on_press: then: - switch.toggle: switch2 - platform: gpio name: "input3" pin: pcf8574: pcf8574_hub_input # Use pin number 0 number: 2 # One of INPUT or OUTPUT mode: INPUT inverted: false on_press: then: - switch.toggle: switch3 - platform: gpio name: "input4" pin: pcf8574: pcf8574_hub_input # Use pin number 0 number: 3 # One of INPUT or OUTPUT mode: INPUT inverted: false on_press: then: - switch.toggle: switch4 - platform: gpio name: "input5" pin: pcf8574: pcf8574_hub_input # Use pin number 0 number: 4 # One of INPUT or OUTPUT mode: INPUT inverted: false on_press: then: - switch.toggle: switch5 - platform: gpio name: "input6" pin: pcf8574: pcf8574_hub_input # Use pin number 0 number: 5 # One of INPUT or OUTPUT mode: INPUT inverted: false on_press: then: - switch.toggle: switch6 - platform: gpio name: "input7" pin: pcf8574: pcf8574_hub_input # Use pin number 0 number: 6 # One of INPUT or OUTPUT mode: INPUT inverted: false on_press: then: - switch.toggle: switch7 - platform: gpio name: "input8" pin: pcf8574: pcf8574_hub_input # Use pin number 0 number: 7 # One of INPUT or OUTPUT mode: INPUT inverted: false on_press: then: - switch.toggle: switch8 # Example configuration entry dallas: - pin: GPIO14 update_interval: 5s sensor: - platform: dallas address: 0xE701202C5ADED628 name: "Temperature_1" id: Temperature_1 - platform: dallas address: 0xBE012115DCBEBC28 name: "Temperature_2" id: Temperature_2 - platform: adc pin: GPIO34 name: "Analog-IN1" update_interval: 5s attenuation: 11db - platform: adc pin: GPIO35 name: "Analog-IN2" update_interval: 5s attenuation: 11db light: - platform: fastled_clockless chipset: WS2812B pin: GPIO33 # Pin Define connected with LED strip num_leds: 150 #LEDs number rgb_order: GRB name: "light_strip" effects: - addressable_rainbow: ##defined 7 effects styles - addressable_color_wipe: - addressable_scan: - addressable_twinkle: - addressable_random_twinkle: - addressable_fireworks: - addressable_flicker: ------------------------------------------------------------------------------- KC868-A8/A4 http command list for third party software integration: read relay state: http://192.168.1.199/switch/switch1 control relay: http://192.168.1.199/switch/switch1/turn_on http://192.168.1.199/switch/switch1/turn_off http://192.168.1.199/switch/switch1/toggle read DI state: http://192.168.1.199/binary_sensor/input1 read temperature: http://192.168.1.199/sensor/temperature_1 read analog input: http://192.168.1.199/sensor/analog-in1 read LED strip: http://192.168.1.199/light/light_strip control LED strip: http://192.168.1.199/light/light_strip/turn_on http://192.168.1.199/light/light_strip/turn_off http://192.168.1.199/light/light_strip/turn_toggle debug send command for TEST example: curl -X POST http://192.168.1.199/switch/switch1/toggle RE: Lesson27- KC868-A8 integrate home assistant by ESPHome demo and http command - WAGNER RAMOS - 07-29-2022 OLA, PODERIA ME PASSAR O ESQUEMA DE LIGAÇÃO DA FITA DE LED? RE: Lesson27- KC868-A8 integrate home assistant by ESPHome demo and http command - admin - 07-29-2022 VCC,DATA,GND, only 3 wires. |
