KC868-D8 home assistant configuration.yaml update - Printable Version +- Smart Home Automation Forum (https://www.kincony.com/forum) +-- Forum: Technical Support (https://www.kincony.com/forum/forumdisplay.php?fid=1) +--- Forum: News (https://www.kincony.com/forum/forumdisplay.php?fid=5) +--- Thread: KC868-D8 home assistant configuration.yaml update (/showthread.php?tid=1152) |
KC868-D8 home assistant configuration.yaml update - admin - 11-17-2021 follows support turn ON/OFF lamp by click "lamp" ico in home assistant. light: - platform: mqtt name: dimmer1 unique_id: dimmer1 schema: template command_topic: "dimmer/xxxxxxxxxxxxxxxxxxxxxxxxxxxx/set" state_topic: "dimmer/xxxxxxxxxxxxxxxxxxxxxxxxxxxx/state" command_on_template: > {%- if brightness is defined -%} ,{"dimmer1":{"value":{{(brightness / 255 * 100) | int - 1}}} {%- else -%} ,'{"dimmer1":{"value":99}}' {%- endif -%} command_off_template: '{"dimmer1":{"value":0}}' state_template: > {%- if value_json.dimmer1.value == 0 -%} off {%- else -%} on {%- endif -%} brightness_template: '{{(value_json.dimmer1.value / 99 * 255)| int}}' |
