KC868-A Pins to HomeSpan HomeKit - Printable Version +- Smart Home Automation Forum (https://www.kincony.com/forum) +-- Forum: Technical Support (https://www.kincony.com/forum/forumdisplay.php?fid=1) +--- Forum: KC868-A series and Uair Smart Controller (https://www.kincony.com/forum/forumdisplay.php?fid=6) +--- Thread: KC868-A Pins to HomeSpan HomeKit (/showthread.php?tid=1574) |
KC868-A Pins to HomeSpan HomeKit - glock4101 - 12-31-2021 Hello, I would like to use my controller for homekit control. I found out from the instructional videos that Relay 3 and 4 are on pins 2 and 15. I would like to use more relays, and configure digital inputs as switches. In further configuration I would like to use analog inputs and a temperature sensor. RE: KC868-A Pins to HomeSpan HomeKit - admin - 01-01-2022 you can add more relay channel by edit code, that just a example. which board model you are using? |
