KC868-H32BS v 1.44 x MQTT - Printable Version +- Smart Home Automation Forum (https://www.kincony.com/forum) +-- Forum: Technical Support (https://www.kincony.com/forum/forumdisplay.php?fid=1) +--- Forum: KC868-HxB series Smart Controller (https://www.kincony.com/forum/forumdisplay.php?fid=2) +--- Thread: KC868-H32BS v 1.44 x MQTT (/showthread.php?tid=1677) |
KC868-H32BS v 1.44 x MQTT - rodrigomallmann - 01-27-2022 Hello all right, I'm starting to integrate kc868-h32bs v1.44 via mqtt in home assistant v2021.12.10. However, when I check if the settings in the configuration.yaml file are correct. Invalid config for [switch]: required key not provided @ data['platform']. Got None. (See /config/configuration.yaml, line 28). RE: KC868-H32BS v 1.44 x MQTT - admin - 01-27-2022 upload your configuration.yaml content, now i don't know what problem with you. also here is configuration.yaml guide for H32BS: https://www.kincony.com/kc868-h32b-integrate-home-assistant-by-mqtt.html RE: KC868-H32BS v 1.44 x MQTT - rodrigomallmann - 01-28-2022 Hi, I managed to solve it. I only put the configuration codes of an input and a relay, but when I completed all the code it worked. Thanks. RE: KC868-H32BS v 1.44 x MQTT - admin - 01-28-2022 ok, you are welcome. |
