Switch 24v DC KC868-Ax - Printable Version +- Smart Home Automation Forum (https://www.kincony.com/forum) +-- Forum: Technical Support (https://www.kincony.com/forum/forumdisplay.php?fid=1) +--- Forum: KC868-Server Raspberry Pi4 local server (https://www.kincony.com/forum/forumdisplay.php?fid=17) +--- Thread: Switch 24v DC KC868-Ax (/showthread.php?tid=2012) |
Switch 24v DC KC868-Ax - fabuena - 07-04-2022 I just bought a KC868-A8 and I want to switch on/off a 24v DC signal. It is posible? RE: Switch 24v DC KC868-Ax - admin - 07-04-2022 KC868-A8 board work with DC12v power supply, but if you want to use relay to control 24v DC, it's no problem, just not let A8 board's power use by DC24V. RE: Switch 24v DC KC868-Ax - fabuena - 07-04-2022 (07-04-2022, 01:07 PM)admin Wrote: KC868-A8 board work with DC12v power supply, but if you want to use relay to control 24v DC, it's no problem, just not let A8 board's power use by DC24V. Perfect. Thank you very much RE: Switch 24v DC KC868-Ax - admin - 07-04-2022 you are welcome. RE: Switch 24v DC KC868-Ax - admin - 06-10-2024 sorry, don't understand your problem. you can post your yaml file. |
