KC868-A8 PCB updated V1.5 - Printable Version +- Smart Home Automation Forum (https://www.kincony.com/forum) +-- Forum: Technical Support (https://www.kincony.com/forum/forumdisplay.php?fid=1) +--- Forum: News (https://www.kincony.com/forum/forumdisplay.php?fid=5) +--- Thread: KC868-A8 PCB updated V1.5 (/showthread.php?tid=2110) |
KC868-A8 PCB updated V1.5 - admin - 08-04-2022 new pcb v1.5 of KC868-A8, replaced USB-C with MiniUSB port.
RE: KC868-A8 PCB updated V1.5 - macek - 08-04-2022 Very good news, I am waiting for a board with an input connect to I2C extender for KC868-A8/A8S .
RE: KC868-A8 PCB updated V1.5 - admin - 08-04-2022 KC868-A8/A8S both have I2C extender RE: KC868-A8 PCB updated V1.5 - macek - 08-04-2022 (08-04-2022, 11:13 AM)admin Wrote: KC868-A8/A8S both have I2C extender Exactly, but I needs a board (with only dry contact inputs, example input on PCF8574) that we connect to KC868-A8/A8S, to I2C extender port. KC868-A128 ESP32 board or KC868-AI ESP32 input module it is too big, it will not fit into the POWER DISTRIBUTION BOX (https://simple.wikipedia.org/wiki/Distribution_board). RE: KC868-A8 PCB updated V1.5 - admin - 08-04-2022 do you want a board only have input via PCF8574? how long between the "IIC input board" with KC868-A8/A8S? RE: KC868-A8 PCB updated V1.5 - admin - 08-04-2022 8 channel in one i2c extend board? RE: KC868-A8 PCB updated V1.5 - macek - 08-05-2022 (08-04-2022, 09:44 PM)admin Wrote: do you want a board only have input via PCF8574?Yes, expansion board (with only input, input channel use optocoupler isolation,) for KC868-A8/A8S, like this - https://prnt.sc/UUCZXgM3QPQG Can be installed above (on top) the KC868-A8/A8S board , there is a lot of space, something like - https://boneio.eu/img/boneIO_v0.2render.png ESPHome support PCF8574 I/O Expander or MCP230xx I/O Expander. Kincony uses the PCF8574 expander everywhere. (08-04-2022, 11:41 PM)admin Wrote: 8 channel in one i2c extend board? It's the minimum, but it's better if the 16 channel will be. 16 connectors will fit on the side of the case. RE: KC868-A8 PCB updated V1.5 - admin - 08-05-2022 ok, i see, thanks for your suggestion. RE: KC868-A8 PCB updated V1.5 - admin - 08-05-2022 I suggest that it is better to use a complete relay motherboard, which is more stable than using I2C expansion mode. I2C mainly use PCB wire, use cable will not stable maybe. RE: KC868-A8 PCB updated V1.5 - macek - 08-08-2022 (08-05-2022, 02:54 PM)admin Wrote: I suggest that it is better to use a complete relay motherboard,I don't think we understand each other, I don't need another complete relay board, I need a board with more inputs. All Kincony products have the same number of digital (dry contact) inputs and digital outputs (relay) - one digital input (button) for one relay (light). This is enough for 4 rooms - 2 buttons for 2 light when use KC868-A8/A8S board. But in a smart home, in a one room, I have more digital inputs: - a motion sensor - a door opening sensor - a window opening sensor - a lock sensor I have nowhere to connect these sensors to have all the automation (ESPHome automation) in one KC868-A8 / A8S controller: binary_sensor: - platform: gpio name: "motion-sensor1" on_press: then: - switch.turn_on: switch1 Final conclusions: KC868 ESP32 board should have more inputs: more connectors on the motherboard or additional inputs on the expansion board connected to the I2C port on motherboard. |
