KC868-H32BS work with KC868-E16 - Printable Version +- Smart Home Automation Forum (https://www.kincony.com/forum) +-- Forum: Technical Support (https://www.kincony.com/forum/forumdisplay.php?fid=1) +--- Forum: Schematic & diagram & Dimensions of KinCony PCB layout CAD file (https://www.kincony.com/forum/forumdisplay.php?fid=33) +--- Thread: KC868-H32BS work with KC868-E16 (/showthread.php?tid=2180) |
KC868-H32BS work with KC868-E16 - admin - 08-24-2022 RE: KC868-H32BS work with KC868-E16 - JoeM - 12-20-2022 Hi, what wire crosssection is used betweeen H32BS and E16 (R1-R16)? RE: KC868-H32BS work with KC868-E16 - admin - 12-20-2022 you can use any wire, it's very low current. almost mA level. RE: KC868-H32BS work with KC868-E16 - JoeM - 12-20-2022 (12-20-2022, 09:43 AM)admin Wrote: you can use any wire, it's very low current. almost mA level. Thanks. I have 2x32bs, 2xE16 and 1xa8 What is power of DC transformer required to supply all equipment? RE: KC868-H32BS work with KC868-E16 - admin - 12-21-2022 dc12v 4.5A power supply. |
