Need smart sound System - Printable Version +- Smart Home Automation Forum (https://www.kincony.com/forum) +-- Forum: Technical Support (https://www.kincony.com/forum/forumdisplay.php?fid=1) +--- Forum: News (https://www.kincony.com/forum/forumdisplay.php?fid=5) +--- Thread: Need smart sound System (/showthread.php?tid=2330) |
Need smart sound System - engmohades - 10-04-2022 Are there smart sound System kincony Or Can you suggest a compatible kincony smart sound System or home assistant ? RE: Need smart sound System - admin - 10-04-2022 do you means audio amplifier? RE: Need smart sound System - engmohades - 10-05-2022 Yes and i want play smart sound System in home assistant RE: Need smart sound System - admin - 10-05-2022 i think you can use KC868-AG to send IR signal to control your sound system, also can work with TV , air conditioner. another way, if your sound system is smart type, support with home assistant, so that can directly integrate to home assistant. you can check supported list in home assistant: https://www.home-assistant.io/integrations/ |
