I would like to suggest to you the following - Printable Version +- Smart Home Automation Forum (https://www.kincony.com/forum) +-- Forum: Technical Support (https://www.kincony.com/forum/forumdisplay.php?fid=1) +--- Forum: News (https://www.kincony.com/forum/forumdisplay.php?fid=5) +--- Thread: I would like to suggest to you the following (/showthread.php?tid=2502) |
I would like to suggest to you the following - engmohades - 01-08-2023 Hello, every on e dear kincony I would like to suggest to you the following 1- Adding a settings page to trigger the 6 inputs in the output of the H32B PRO relay, such as the Interlock settings page Because when the internet or Toya server stops, automation will not work 2- Updating the Touch and Montary switches by adding an rs485 bus to it bluit in , not adding another special piece to it 3- Run all Kincony products that contain rs485 to reduce the large number of wires used in connection, and by making one software and programming the entire system through it RE: I would like to suggest to you the following - admin - 01-08-2023 1. if you want work in locally, add KC868-AK use for INPUT trigger H32B Pro OUTPUT is perfect. ok, i know your means, maybe in furture will update. 2. yes, RS485 switch panel can be used directly, use KC868-HA just want to use old switch panel. 3. rs485 can reduce cable, exactly. use dry contact signal just want let lowest failure rate. |
