h32bs mqtt - Printable Version +- Smart Home Automation Forum (https://www.kincony.com/forum) +-- Forum: Technical Support (https://www.kincony.com/forum/forumdisplay.php?fid=1) +--- Forum: KC868-HxB series Smart Controller (https://www.kincony.com/forum/forumdisplay.php?fid=2) +--- Thread: h32bs mqtt (/showthread.php?tid=2564) |
h32bs mqtt - ismail - 02-11-2023 hello... first: ihave trying to connect kc868-h32bs to home assistant via mqtt I followed this method: https://www.youtube.com/watch?v=Yrat7hVzXRw but i think its need to be updated because the mosquitto broker has a new way to configured so can you plz update this section second: where to found the new firmware version for h32bs thats compatible with mqtt. thank you RE: h32bs mqtt - admin - 02-12-2023 1: the newest mqtt syntax of home assistant config yaml file, you can download at here: https://www.kincony.com/kc868-h32b-integrate-home-assistant-by-mqtt.html 2: i think you not need to update firmware, because the new syntax only just changed by yaml file, not need changed by hardware. if you want to update the newest firmware, here is the newest link of H32BS firmware download: https://www.kincony.com/forum/showthread.php?tid=2455 |
