How can the dashboard be customized for each user? - Printable Version +- Smart Home Automation Forum (https://www.kincony.com/forum) +-- Forum: Technical Support (https://www.kincony.com/forum/forumdisplay.php?fid=1) +--- Forum: Home automation training courses (https://www.kincony.com/forum/forumdisplay.php?fid=18) +--- Thread: How can the dashboard be customized for each user? (/showthread.php?tid=2584) |
How can the dashboard be customized for each user? - engmohades - 02-18-2023 In the case of using the home assistant How can a custom dashboard be made for each user, separate from the other user? So that no user can access the page of the other user RE: How can the dashboard be customized for each user? - admin - 02-18-2023 in home assistant: Configure UI → Select dashboard → edit dashboard name → select visibility → select users. |
