kc868-h32bs - Printable Version +- Smart Home Automation Forum (https://www.kincony.com/forum) +-- Forum: Technical Support (https://www.kincony.com/forum/forumdisplay.php?fid=1) +--- Forum: KC868-HxB series Smart Controller (https://www.kincony.com/forum/forumdisplay.php?fid=2) +--- Thread: kc868-h32bs (/showthread.php?tid=2605) |
kc868-h32bs - Philadam - 02-25-2023 I think I might have already asked this, but will the H32BS OR the kc868-server work with KC868-A16? RE: kc868-h32bs - admin - 02-25-2023 what software will use? do you want to use home assistant? sorry, i don't know what's your means of "work with"? RE: kc868-h32bs - Philadam - 02-25-2023 There so many different components, I am trying to sort through them. Don't know what software I am going use yet, but do they share the same protocols, i.e. if I connect both to my network could they be seen as one unit with 48 inputs and 48 outputs. RE: kc868-h32bs - admin - 02-26-2023 sure, if you use home assistant, H32BS and A16 all can work with home assistant, just integrate them to KC868-Server. RE: kc868-h32bs - Philadam - 02-26-2023 if I download "KCS" firmware to A16 will it work with H32BS without the server? RE: kc868-h32bs - admin - 02-26-2023 sure, if you want A16 remote control by mobile phone , just add to buy tuya licence from KinCony. if you want only use in local network, no problem, you can control by webpage or by "KBOX" mobile phone app. RE: kc868-h32bs - Philadam - 02-26-2023 Thanks RE: kc868-h32bs - admin - 02-26-2023 you are welcome. |
