how to install docker on KC868-Server CM4 by raspberry pi OS - Printable Version +- Smart Home Automation Forum (https://www.kincony.com/forum) +-- Forum: Technical Support (https://www.kincony.com/forum/forumdisplay.php?fid=1) +--- Forum: Home automation training courses (https://www.kincony.com/forum/forumdisplay.php?fid=18) +--- Thread: how to install docker on KC868-Server CM4 by raspberry pi OS (/showthread.php?tid=2674) |
how to install docker on KC868-Server CM4 by raspberry pi OS - admin - 03-13-2023 A. install docker on KC868-Server CM4 on raspberry pi OS 1. sudo curl -sSL https://get.docker.com | sh 2. sudo docker run hello-world this test whether docker install correct. 3. sudo systemctl daemon-reload 4. sudo systemctl docker 5. sudo systemctl start docker B. install GUI portainer 1. sudo docker pull portainer/portainer 2. sudo docker volume create portainer_data 3. docker run -d -p 9000:9000 --name portainer --restart always -v /var/run/docker.sock:/var/run/docker.sock -v portainer_data:/data portainer/portainer 4. login web browser by http://ip:9000 |
