[KC868-H32B][MQTT] Home Assistant switches do not restore state after reboot - Printable Version +- Smart Home Automation Forum (https://www.kincony.com/forum) +-- Forum: Technical Support (https://www.kincony.com/forum/forumdisplay.php?fid=1) +--- Forum: KC868-HxB series Smart Controller (https://www.kincony.com/forum/forumdisplay.php?fid=2) +--- Thread: [KC868-H32B][MQTT] Home Assistant switches do not restore state after reboot (/showthread.php?tid=273) |
[KC868-H32B][MQTT] Home Assistant switches do not restore state after reboot - basten - 05-12-2021 Home assistant switches work well via ethernet MQTT but do not restore their states after HA reboot (all stay off). Firmware version is H32B_V4.24. RE: [KC868-H32B][MQTT] Home Assistant switches do not restore state after reboot - basten - 05-14-2021 This is because of we have one MQTT state topic for all relays and last state is not persisted by broker. Possible solution here could be to have separate state topics (one per relay) and publishing states with RETAINED flag set. RE: [KC868-H32B][MQTT] Home Assistant switches do not restore state after reboot - admin - 05-14-2021 we will update firmware for HA reboot update state. when finished, i will tell reply you. RE: [KC868-H32B][MQTT] Home Assistant switches do not restore state after reboot - admin - 05-22-2021 you can update firmware now: https://www.kincony.com/forum/showthread.php?tid=276 RE: [KC868-H32B][MQTT] Home Assistant switches do not restore state after reboot - basten - 05-25-2021 works good, thank you! |
