KC868-AIO ESP32 I/O pin define - Printable Version +- Smart Home Automation Forum (https://www.kincony.com/forum) +-- Forum: Technical Support (https://www.kincony.com/forum/forumdisplay.php?fid=20) +--- Forum: KC868-AIO (https://www.kincony.com/forum/forumdisplay.php?fid=46) +--- Thread: KC868-AIO ESP32 I/O pin define (/showthread.php?tid=2735) Pages:
1
2
KC868-AIO ESP32 I/O pin define - admin - 03-24-2023 ESP32 ANALOG_A1 GPIO36 For (Analog Multiplexer: cd74hc4067) to extend "analog input" 1-16 ESP32 ANALOG_A2 GPIO39 analog input 17 ESP32 ANALOG_A3 GPIO34 analog input 18 ESP32 ANALOG_A4 GPIO35 analog input 19 IIC Bus:A SDA-A:GPIO4 SCL-A:GPIO16 PCF8575:U40 (output 1-16): 100 100 = 0x24 PCF8575:U41 (output 17-32): 100 101 = 0x25 PCF8575:U42 (output 33-38): 100 110 = 0x26 cd74hc4067 S0-A: PCF8575->U42->P10 (output 33) S1-B: PCF8575->U42->P11 (output 34) S2-C: PCF8575->U42->P12 (output 35) S3-D: PCF8575->U42->P13 (output 36) free LEDs: LED-D7: PCF8575->U42->P14 (output 37) LED-D8: PCF8575->U42->P15 (output 38) ----------------------------------------------------------------------------------- PCF8575:U35 (input 1-16): 100 001 = 0x21 PCF8575:U37 (input 17-32): 100 010 = 0x22 PCF8575:U38 (input 33-48): 100 011 = 0x23 PCF8575:U42 (input 49-58): 100 110 = 0x26 PCF8575->U42->P0 (input 49) PCF8575->U42->P1 (input 50) PCF8575->U42->P2 (input 51) PCF8575->U42->P3 (input 52) PCF8575->U42->P4 (input 53) PCF8575->U42->P5 (input 54) PCF8575->U42->P6 (input 55) PCF8575->U42->P7 (input 56) PCF8575->U42->P14 (input 57) PCF8575->U42->P15 (input 58) ----------------------------------------------------------------------------------------- PCA9685: address 0x00 ----------------------------------------------------------------------------------------- Button-S1: reset Button-S2: GPIO0 Button-S3: PCF8575->U42->P14 (input 57) Button-S4: PCF8575->U42->P15 (input 58) ------------------------------------------------------------------------------------------- DS18B20/DHT11/DHT21/LED strip -(TP1): GPIO14 DS18B20/DHT11/DHT21/LED strip -(TP2): GPIO5 ------------------------------------------------------------------------------------------- Ethernet (LAN8720) I/O define: #define ETH_ADDR 0 #define ETH_POWER_PIN -1 #define ETH_MDC_PIN 23 #define ETH_MDIO_PIN 18 #define ETH_TYPE ETH_PHY_LAN8720 #define ETH_CLK_MODE ETH_CLOCK_GPIO17_OUT ------------------------------------------------------------------------------------------- RS485: RXD(A): GPIO32 TXD(B): GPIO33 ------------------------------------------------------------------------------------------ 4G GSM Module / Extend serial port: RXD: GPIO13 TXD: GPIO15 --------------------------------------------------------------------------------------------- DS3231 RTC module: IIC address 0x68 EEPROM's default I2C address is 0x57 RE: KC868-AIO ESP32 I/O pin define - xarouli5 - 03-28-2025 Can gpio05 and gpio14 work at the same time? I tried on one_wire to define both but accepts one OR the other. I want dht11 on one pin and DS18b20 on the other. RE: KC868-AIO ESP32 I/O pin define - admin - 03-29-2025 Do you use KCS firmware or ESPHome? RE: KC868-AIO ESP32 I/O pin define - xarouli5 - 03-29-2025 Esp home. We need two sensors: (DS18b20) on Tp1 and dht on tp2. Can both be used at the same time? How many on each channel using both channels? RE: KC868-AIO ESP32 I/O pin define - admin - 03-29-2025 sure, you can use two gpio at the same time. if you using ESPHome, also support one gpio with multi DS18B20 sensors. RE: KC868-AIO ESP32 I/O pin define - xarouli5 - 03-29-2025 One gpio with many DS18b20 Also the other gpio with many Dht11? RE: KC868-AIO ESP32 I/O pin define - admin - 03-29-2025 yes, that according to ESPHome, one gpio can work with multi ds18b20 sensors. But one gpio ONLY work with one DHT11 sensor. RE: KC868-AIO ESP32 I/O pin define - xarouli5 - 04-14-2025 I have a DS18b20 on GPIO14 and working. Trying to use a Dht11 on GPIO05. The code I use (try) is: # one_wire: - platform: gpio pin: GPIO14 id: one_wire1 - platform: gpio pin: GPIO05 id: one_wire2 Sensor - platform: dallas_temp name: #AIO DS18B20 #1" update_interval: 10s one_wire_id: one_wire1 - platform: dht model: DHT11 one_wire_id: one_wire2 temperature: name: "Temperature2" humidity: name: "Humidity2" update_interval: 10s # The error I get is: INFO ESPHome 2024.12.4 INFO Reading configuration /config/esphome/aio.yaml... WARNING GPIO5 is a strapping PIN and should only be used for I/O with care. Attaching external pullup/down resistors to strapping pins can cause unexpected failures. See https://esphome.io/guides/faq.html#why-am-i-getting-a-warning-about-strapping-pins Failed config sensor.dht: [source /config/esphome/aio.yaml:429] 'pin' is a required option for [sensor.dht]. platform: dht model: DHT11 [one_wire_id] is an invalid option for [sensor.dht]. Please check the indentation. one_wire_id: one_wire2 temperature: name: Temperature2 humidity: name: Humidity2 update_interval: 10s What am I doing wrong? I am using 3.3v for Dht11. Tried 2 different sensors, both same error. https://a.aliexpress.com/_EIdTg JK https://a.aliexpress.com/_EQCKU9Q (04-14-2025, 07:39 PM)xarouli5 Wrote: I have a DS18b20 on GPIO14 and working. Trying to use a Dht11 on GPIO05. RE: KC868-AIO ESP32 I/O pin define - admin - 04-14-2025 you can update your esphome to 2025.3 now the one wire sensor yaml format have changed, you can check with esphome webpage. RE: KC868-AIO ESP32 I/O pin define - xarouli5 - 04-15-2025 For any other looking the same: The problem was not the version of ESPHome, though I updated had the same error as before. The code working: # one_wire: - platform: gpio pin: GPIO14 id: one_wire1 - platform: gpio pin: GPIO05 id: one_wire2 #no need to define one_wire2 for a reason I don't understand but it works like this. # Sensor - platform: dallas_temp name: #AIO DS18B20 #1" update_interval: 10s one_wire_id: one_wire1 - platform: dht pin: GPIO05 temperature: name: "Temperature DHT11" humidity: name: "Humidity DHT11" update_interval: 60s # |
