KC868-A8 with Motion Sensor HC-SR501 - Printable Version +- Smart Home Automation Forum (https://www.kincony.com/forum) +-- Forum: Technical Support (https://www.kincony.com/forum/forumdisplay.php?fid=20) +--- Forum: KC868-A8 (https://www.kincony.com/forum/forumdisplay.php?fid=23) +--- Thread: KC868-A8 with Motion Sensor HC-SR501 (/showthread.php?tid=3041) |
KC868-A8 with Motion Sensor HC-SR501 - vijjav - 07-06-2023 I need help connecting pir motion sensor with A8 board. Should i connect with DI 1-8 or s2, s3 terminals? Here is the code part I am currently using. Code: switch:RE: KC868-A8 with Motion Sensor HC-SR501 - admin - 07-06-2023 if your PIR sensor is dry contact signal, all port can use. just DI1-8 support wire long distance, support 300 meter wire no problem. S2, S3 port by short distance. suggest use DI1-8 port. RE: KC868-A8 with Motion Sensor HC-SR501 - vijjav - 07-07-2023 I've connected my PIR to D8, but my output got stuck at "Cleared". I did a wire short test between D8 and GND, no response. But when is short D8 with +12V , then the pir got detected and released when short is disconnected. It is suppose to be D8 vs GND, what I am missing here? RE: KC868-A8 with Motion Sensor HC-SR501 - admin - 07-07-2023 what D8?? DI8? it set by your PIR sensor use by "NC" or "NO". A8 digital input just use by 0v or 12v logical voltage. RE: KC868-A8 with Motion Sensor HC-SR501 - vijjav - 07-07-2023 I use DI terminal 8 and PIR uses NO This is the PIR sensor I am using https://components101.com/sensors/hc-sr501-pir-sensor RE: KC868-A8 with Motion Sensor HC-SR501 - admin - 07-07-2023 change the config line: inverted: false ----> inverted: true RE: KC868-A8 with Motion Sensor HC-SR501 - vijjav - 07-08-2023 (07-07-2023, 11:15 PM)admin Wrote: change the config line: I've changed the config inverted as true. - platform: gpio name: "a8_study_room_pir" device_class: motion on_press: then: - switch.turn_on: a8_study_room_pir on_release: then: - switch.turn_off: a8_study_room_pir pin: pcf8574: pcf8574_hub_in_1 number: 7 mode: INPUT inverted: true But still is not getting detected, after changing inverted as true, Motion detection is inverted when shorting D1 8 with +12 V. Which means when motion detected the logs says it is cleared, and motion clear inverted as detected. RE: KC868-A8 with Motion Sensor HC-SR501 - admin - 07-08-2023 open your PIR sensor, maybe inside on PCB have jumper, it can set "NO" or "NC", you can chose it. |
