Double/long click - Printable Version +- Smart Home Automation Forum (https://www.kincony.com/forum) +-- Forum: Technical Support (https://www.kincony.com/forum/forumdisplay.php?fid=1) +--- Forum: KC868-HxB series Smart Controller (https://www.kincony.com/forum/forumdisplay.php?fid=2) +--- Thread: Double/long click (/showthread.php?tid=307) Pages:
1
2
Double/long click - eladn - 06-21-2021 Hi One of your logic units (like KC868-COL) or the switch terminal board is able to detect double-click and/or long-click on the digital input from the self-reset switch? I would like to set it to perform some other action (like turning off a group of lights) without having a dedicated switch just for it. In other words: on a certain switch: (i) normal click would be programmed to do action_1, (ii) double click would do action_2; and (iii) long click would do action_3. Thanks. RE: Double/long click - admin - 06-22-2021 double click can't use now, hold-on click mode can be used, our customer already is using. There is hold on time for DI(digital input) set by COL PC software. RE: Double/long click - eladn - 06-22-2021 (06-22-2021, 12:48 AM)admin Wrote: double click can't use now, hold-on click mode can be used, our customer already is using. There is hold on time for DI(digital input) set by COL PC software. Thanks. I vote +1 for the double-click feature request
RE: Double/long click - admin - 06-23-2021 we are considering, maybe in furture will update firmware for double click action. RE: Double/long click - Sten - 06-26-2021 (06-23-2021, 12:19 AM)admin Wrote: we are considering, maybe in furture will update firmware for double click action. I am waiting with interest I hope it will happend soon RE: Double/long click - Sten - 07-07-2021 (06-26-2021, 08:21 PM)Sten Wrote:(06-23-2021, 12:19 AM)admin Wrote: we are considering, maybe in furture will update firmware for double click action. I hope you don't forget your existing customers. The update will also be to COL not just COLB Best regatds Stgen RE: Double/long click - admin - 07-07-2021 which relay controller model you have use? RE: Double/long click - Sten - 09-10-2021 (07-07-2021, 11:30 AM)admin Wrote: which relay controller model you have use? I have: 1)KC868-32 2)KC868-32B 3)KC868-COL RE: Double/long click - athxp - 09-12-2021 I would also be interested in the double click. use COL + 2 h32L RE: Double/long click - admin - 09-12-2021 now KC868-H32BS support double click mode. |
