Using analogue inputs as digital inputs - Printable Version +- Smart Home Automation Forum (https://www.kincony.com/forum) +-- Forum: Technical Support (https://www.kincony.com/forum/forumdisplay.php?fid=1) +--- Forum: KC868-HxB series Smart Controller (https://www.kincony.com/forum/forumdisplay.php?fid=2) +--- Thread: Using analogue inputs as digital inputs (/showthread.php?tid=308) |
Using analogue inputs as digital inputs - eladn - 06-22-2021 Hi. KC868-COL hasĀ 16 DIs and 16 AIs. Can i set an AI to be operated as a simple DI? I want to haveĀ 32 DIs. Alternatively, can i have multiple units of KC868-COL? Thanks. RE: Using analogue inputs as digital inputs - admin - 06-23-2021 yes, it's no problem, you can set such as AI>xV. because DI input just connect with a constant voltage value. The different is AI's input cable not too long. because the DI we have use extend distance circuit, almost 500 meter is also no problem for using dry contact device. RE: Using analogue inputs as digital inputs - eladn - 06-30-2021 (06-23-2021, 12:22 AM)admin Wrote: yes, it's no problem, you can set such as AI>xV. because DI input just connect with a constant voltage value. The different is AI's input cable not too long. because the DI we have use extend distance circuit, almost 500 meter is also no problem for using dry contact device. Great thanks!! |
