KC868-AI RS485 & EspHome - Printable Version +- Smart Home Automation Forum (https://www.kincony.com/forum) +-- Forum: Technical Support (https://www.kincony.com/forum/forumdisplay.php?fid=20) +--- Forum: KC868-AI (https://www.kincony.com/forum/forumdisplay.php?fid=29) +--- Thread: KC868-AI RS485 & EspHome (/showthread.php?tid=3145) |
KC868-AI RS485 & EspHome - pietervanstee - 08-14-2023 Hi, I'm setting up my KC868-AI in EspHome, but I can't seem to find any information about the integration of RS485 in there. Please let me know how I can add an additional device (RS485 Ultrasone Wind Snelheid En Richting Sensor Temperatuur Vochtigheid Noise PM2.5 Druk Licht Neerslag Kleine Weerstation) Thanks Pieter RE: KC868-AI RS485 & EspHome - admin - 08-14-2023 if you are using RS485 sensor, you can connect to raspberry pi's USB-RS485 adapter directly. then integrate to home assistant by it's protocol. RE: KC868-AI RS485 & EspHome - xoor - 03-03-2024 @admin Is it possible to use fw KCS KC868-AI as modbus GW? I have a modbus-RTU device and I wanted to connect it via AI RS485 and use it as modbus-tcp/UPD/HTTP requests. RE: KC868-AI RS485 & EspHome - admin - 03-04-2024 KCS let RS485 modbus work as "SLAVE" mode. if you want work as "MASTER" mode, i think you can config KC868-AI by ESPHome, so that you can do anything. |
