how to add Raspberry Pi GPIO integration to home assistant for SERVER-MINI - Printable Version +- Smart Home Automation Forum (https://www.kincony.com/forum) +-- Forum: Technical Support (https://www.kincony.com/forum/forumdisplay.php?fid=1) +--- Forum: KinCony Server-Mini / Server-16 Raspberry Pi4 relay module (https://www.kincony.com/forum/forumdisplay.php?fid=53) +--- Thread: how to add Raspberry Pi GPIO integration to home assistant for SERVER-MINI (/showthread.php?tid=3184) |
how to add Raspberry Pi GPIO integration to home assistant for SERVER-MINI - admin - 08-22-2023 1. make home assistant SD card for KinCony Server-16. download https://www.raspberrypi.com/software/ 2. install HACS addon (use by SSH) https://hacs.xyz/docs/setup/download/ 3. install "rpi_gpio" through HACS. https://github.com/thecode/ha-rpi_gpio 4. config ymal for CM4 GPIOs. install file edit add-on for HA , then config yaml ------------------------------------- switch: - platform: rpi_gpio switches: - port: 5 name: "CM4 relay1" - port: 22 name: "CM4 relay2" - port: 17 name: "CM4 relay3" - port: 4 name: "CM4 relay4" - port: 6 name: "CM4 relay5" - port: 13 name: "CM4 relay6" - port: 19 name: "CM4 relay7" - port: 26 name: "CM4 relay8" binary_sensor: - platform: rpi_gpio sensors: - port: 18 name: "CM4 IN1" invert_logic: true - port: 23 name: "CM4 IN2" invert_logic: true - port: 24 name: "CM4 IN3" invert_logic: true - port: 25 name: "CM4 IN4" invert_logic: true - port: 12 name: "CM4 IN5" invert_logic: true - port: 16 name: "CM4 IN6" invert_logic: true - port: 20 name: "CM4 IN7" invert_logic: true - port: 21 name: "CM4 IN8" invert_logic: true RE: how to add Raspberry Pi GPIO integration to home assistant - kovalank - 08-29-2023 How to synchronize a physical button with a KinCony Server-Mini Raspberry Pi4 relay module? Please give examble code! When a physical button or switch is connected as a binary input, For example, in the code you provided, port 18 is configured as a binary input (CM4 IN1). When this input is low, the Raspberry Pi will enable port5 CM4 relay1, When the input is high, the Raspberry Pi will disable CM4 relay1. RE: how to add Raspberry Pi GPIO integration to home assistant - admin - 08-29-2023 if you are using home assistant, just create "AUTOMATION" in home assistant, when INPUT trigger OUTPUT "TOGGLE" is ok. RE: how to add Raspberry Pi GPIO integration to home assistant - kovalank - 08-30-2023 (08-29-2023, 10:04 PM)admin Wrote: if you are using home assistant, just create "AUTOMATION" in home assistant, when INPUT trigger OUTPUT "TOGGLE" is ok. How it work offline or when network fail, is it work? RE: how to add Raspberry Pi GPIO integration to home assistant - admin - 08-30-2023 it can work without network. RE: how to add Raspberry Pi GPIO integration to home assistant - iulik - 09-26-2023 I'm sorry to resume this topic, but if I don't want to use AUTOMATION from HA, what would be the code to turn on relay 1 with input 1 ??... for example.... Regards RE: how to add Raspberry Pi GPIO integration to home assistant - admin - 09-26-2023 another way, you can install Node-Red software, link the INPUT with OUTPUT. at firstly you need install one software for CM4. |
