Cable length run? - Printable Version +- Smart Home Automation Forum (https://www.kincony.com/forum) +-- Forum: Technical Support (https://www.kincony.com/forum/forumdisplay.php?fid=20) +--- Forum: KC868-M16 / M1 / MB / M30 (https://www.kincony.com/forum/forumdisplay.php?fid=50) +--- Thread: Cable length run? (/showthread.php?tid=3358) |
Cable length run? - deanfourie - 10-03-2023 What is the maximum length of cable run that can be supported for a clamp sensor and still receive accurate readings? Thanks RE: Cable length run? - admin - 10-03-2023 how many distance you want to use? RE: Cable length run? - GabrielRR - 10-04-2023 Which current clamps do you advise for this board? Can you send the link to the store/product? RE: Cable length run? - admin - 10-05-2023 usually use about 1-2 meter, here is CT clamp sensor have supportted: https://www.aliexpress.com/item/1005005527700418.html RE: Cable length run? - Schmick - 11-04-2023 (10-03-2023, 09:53 AM)deanfourie Wrote: What is the maximum length of cable run that can be supported for a clamp sensor and still receive accurate readings? If you need longer clamp sensor cables, would be best to get them in the mA output version. Idea being that the current output doesn't change over wire length, whereas the voltage does. RE: Cable length run? - admin - 11-05-2023 yes, "current" type for long distance cable. "voltage" will reduce when cable very long. |
