A4S stops working - Printable Version +- Smart Home Automation Forum (https://www.kincony.com/forum) +-- Forum: Technical Support (https://www.kincony.com/forum/forumdisplay.php?fid=20) +--- Forum: KC868-A4S (https://www.kincony.com/forum/forumdisplay.php?fid=41) +--- Thread: A4S stops working (/showthread.php?tid=3576) |
A4S stops working - mvtech2430 - 11-30-2023 Hello any idea why my a4s is not working ? i try to re install firmware but this error pops up - failed to initialized - try resetting your device or hold the reset BUTTON. the LAN is not blinking anymore offline in home assistant. PLEASE Help. i also try to hold the esp32 chip its hot is that normal ? RE: A4S stops working - admin - 11-30-2023 what you have done? now you can try to download firmware by USB cable. RE: A4S stops working - mvtech2430 - 11-30-2023 yes already trying to install using USB cable. but there is an error please see attached file installing using esphome RE: A4S stops working - admin - 11-30-2023 i have asked you what you have done before? RE: A4S stops working - mvtech2430 - 11-30-2023 (11-30-2023, 04:44 AM)admin Wrote: i have asked you what you have done before? i install the INA226, connect to DS3231 RTC MODULE SCL SDA 3V3 GND > INA226 = SCL SDA VIN GND INA226 = V+ > + 1.5v AA Battery and GND = - 1.5V AA Battery after connecting just a few minutes A4S board stops working. see attached file for actual photo of INA226 This is the actual what i did. after connect all wire add this code to esphome then i can no longer see A4S in my HA sensor: Code: sensor:please see picture on the actual connection. RE: A4S stops working - admin - 11-30-2023 if you connect a extender battery for testing, you should series connection with a load resistance. now it's short circuit. if esp32 module very hot, maybe is broken, need to replace a new ESP32 module. RE: A4S stops working - mvtech2430 - 11-30-2023 What is the proper connection diagram using this INA226 to monitor my battery Voltage? I will replace the A4S Can you show me how to do it ? Thanks RE: A4S stops working - admin - 12-01-2023 you need add a "LOAD". here is we test with our new design board used INA226, we use a 10ohm resistance as a LOAD. But i am using dc24v power supply for testing. RE: A4S stops working - mvtech2430 - 12-01-2023 Thanks for the info. Maybe we can buy that board for our next project. But for now im using a4s and INA266 module how can i connect to it? Sorry im new to this i cant barley read diagram ?, it will make sense to me if you make simple connection Using INA266 and A4S. Thank you RE: A4S stops working - admin - 12-06-2023 A4S and INA226, use by 3.3v, GND, SDA,SCL 4 wire to connect with each other. |
