connecting sensors to the KC868-A16S module - Printable Version +- Smart Home Automation Forum (https://www.kincony.com/forum) +-- Forum: Technical Support (https://www.kincony.com/forum/forumdisplay.php?fid=20) +--- Forum: KC868-A16S (https://www.kincony.com/forum/forumdisplay.php?fid=47) +--- Thread: connecting sensors to the KC868-A16S module (/showthread.php?tid=3611) |
connecting sensors to the KC868-A16S module - Lamri - 12-02-2023 Hello, I am having trouble connecting sensors to the KC868-A16S module. Can you please send me a wiring diagram for the following sensors: 1- A 220v motion detector PIR with 3 wires on the KC868-A16S module. (Can I connect the output of the 220v sensor with the dry contact input of the KC868-A16S module?) 2- A water level sensor XKC-Y25-V PNP with 4 wires. 3- A water level sensor XKC-Y25-V NPN with 4 wires. 4- A gas leak alarm sensor 4 wires . 5- A smoke detector 4 wires . RE: connecting sensors to the KC868-A16S module - admin - 12-03-2023 where you buy from the sensors? post your sensor details, we need to know every wire define for sensor. RE: connecting sensors to the KC868-A16S module - Lamri - 12-03-2023 1- A water level sensor XKC-Y25-V PNP with 4 wires. 2- A water level sensor XKC-Y25-V NPN with 4 wires. https://fr.aliexpress.com/item/1005002618286780.html?spm=a2g0o.detail.1000014.23.55d6lnwblnwbKe&gps-id=pcDetailBottomMoreOtherSeller&scm=1007.40000.326746.0&scm_id=1007.40000.326746.0&scm-url=1007.40000.326746.0&pvid=18d0f30f-8a64-46c6-a79e-b4bb8e05be70&_t=gps-id:pcDetailBottomMoreOtherSeller,scm-url:1007.40000.326746.0,pvid:18d0f30f-8a64-46c6-a79e-b4bb8e05be70,tpp_buckets:668%232846%238116%23973&pdp_npi=4%40dis%21EUR%214.58%213.94%21%21%214.88%21%21%40211b812f17016413627225528ec82f%2112000034370121662%21rec%21FR%21850710272%21 ![]() 3- A 220v motion detector PIR with 3 wires https://fr.aliexpress.com/item/1005005483880608.html?spm=a2g0o.order_list.order_list_main.53.24535e5bBzukgj&gatewayAdapt=glo2fra ![]() 4- A gas leak alarm sensor 4 wires https://fr.aliexpress.com/item/32981937323.html?spm=a2g0o.order_list.order_list_main.71.24535e5bBzukgj&gatewayAdapt=glo2fra ![]() 5- A smoke detector 4 wires . https://fr.aliexpress.com/item/1005005683899081.html?spm=a2g0o.order_list.order_list_main.131.24535e5bBzukgj&gatewayAdapt=glo2fra RE: connecting sensors to the KC868-A16S module - Lamri - 12-05-2023 can someone help me? RE: connecting sensors to the KC868-A16S module - Lamri - 12-13-2023 can someone help me ? RE: connecting sensors to the KC868-A16S module - admin - 12-14-2023 item 1-2: water level sensor you can connect to A16S' digital input port. item 3: motion detector can't use, it's AC220v version, it connect with AC220v lamp directly. you should chose dry contact output siganl version of PIR. itme4: gas leak sensor: "relay output" of sensor connect to A16S' digital input port. item5: not seen any pin define of the sensor, if the sensor have wire sigal output by "dry contact", also can use for A16S' digital input port. |
