Tuya app by ESPHome in KC868-A16S - Printable Version +- Smart Home Automation Forum (https://www.kincony.com/forum) +-- Forum: Technical Support (https://www.kincony.com/forum/forumdisplay.php?fid=20) +--- Forum: KC868-A16S (https://www.kincony.com/forum/forumdisplay.php?fid=47) +--- Thread: Tuya app by ESPHome in KC868-A16S (/showthread.php?tid=4055) |
Tuya app by ESPHome in KC868-A16S - Lamri - 01-01-2024 Hello, Can you correct the code for me to integrate the Tuya app by ESPHome in KC868-A16S ? external_components: - source: type: git url: https://github.com/hzkincony/esphome-tuya-iot ref: v1.2.0 time: - platform: homeassistant id: homeassistant_time on_turn_on: - lambda: !lambda |- id(tuya_iot_component).property_report("output1", true); on_turn_off: - lambda: !lambda |- id(tuya_iot_component).property_report("output1", false); on_turn_on: - lambda: !lambda |- id(tuya_iot_component).property_report("output2", true); on_turn_off: - lambda: !lambda |- id(tuya_iot_component).property_report("output2", false); on_turn_on: - lambda: !lambda |- id(tuya_iot_component).property_report("output3", true); on_turn_off: - lambda: !lambda |- id(tuya_iot_component).property_report("output3", false); on_turn_on: - lambda: !lambda |- id(tuya_iot_component).property_report("output4", true); on_turn_off: - lambda: !lambda |- id(tuya_iot_component).property_report("output4", false); on_turn_on: - lambda: !lambda |- id(tuya_iot_component).property_report("output5", true); on_turn_off: - lambda: !lambda |- id(tuya_iot_component).property_report("output5", false); on_turn_on: - lambda: !lambda |- id(tuya_iot_component).property_report("output6", true); on_turn_off: - lambda: !lambda |- id(tuya_iot_component).property_report("output6", false); on_turn_on: - lambda: !lambda |- id(tuya_iot_component).property_report("output7", true); on_turn_off: - lambda: !lambda |- id(tuya_iot_component).property_report("output7", false); on_turn_on: - lambda: !lambda |- id(tuya_iot_component).property_report("output8", true); on_turn_off: - lambda: !lambda |- id(tuya_iot_component).property_report("output8", false); on_turn_on: - lambda: !lambda |- id(tuya_iot_component).property_report("output9", true); on_turn_off: - lambda: !lambda |- id(tuya_iot_component).property_report("output9", false); on_turn_on: - lambda: !lambda |- id(tuya_iot_component).property_report("output10", true); on_turn_off: - lambda: !lambda |- id(tuya_iot_component).property_report("output10", false); on_turn_on: - lambda: !lambda |- id(tuya_iot_component).property_report("output11", true); on_turn_off: - lambda: !lambda |- id(tuya_iot_component).property_report("output11", false); on_turn_on: - lambda: !lambda |- id(tuya_iot_component).property_report("output12", true); on_turn_off: - lambda: !lambda |- id(tuya_iot_component).property_report("output12", false); on_turn_on: - lambda: !lambda |- id(tuya_iot_component).property_report("output13", true); on_turn_off: - lambda: !lambda |- id(tuya_iot_component).property_report("output13", false); on_turn_on: - lambda: !lambda |- id(tuya_iot_component).property_report("output14", true); on_turn_off: - lambda: !lambda |- id(tuya_iot_component).property_report("output14", false); on_turn_on: - lambda: !lambda |- id(tuya_iot_component).property_report("output15", true); on_turn_off: - lambda: !lambda |- id(tuya_iot_component).property_report("output15", false); on_turn_on: - lambda: !lambda |- id(tuya_iot_component).property_report("output16", true); on_turn_off: - lambda: !lambda |- id(tuya_iot_component).property_report("output16", false); tuya_iot: id: tuya_iot_component product_id: pxdb......................... device_id: 263.............................. device_secret: Fw9.......................... region: eu # eu, us, eus, weu, in, cn # eu: Central Europe Data Center # us: US West Data Center # eus: US East Data Center # weu: Western Europe Data Center # in: India Data Center # cn: Chinese Data Center on_event: - event_name: property/set then: - lambda: !lambda |- // Append the required switch in switch_map to respond to commands issued by Tuya. static std::map<float, switch_::Switch*> switch_map { { 1, id(a16s-output1) }, { 2, id(a16s-output2) }, { 3, id(a16s-output3) }, { 4, id(a16s-output4) }, { 5, id(a16s-output5) }, { 6, id(a16s-output6) }, { 7, id(a16s-output7) }, { 8, id(a16s-output8) }, { 9, id(a16s-output9) }, { 10, id(a16s-output10) }, { 11, id(a16s-output11) }, { 12, id(a16s-output12) }, { 13, id(a16s-output13) }, { 14, id(a16s-output14) }, { 15, id(a16s-output15) }, { 16, id(a16s-output16) }, }; bool is_target_output = false; bool output_state = false; int output_number = 0; // Modify this number 2 to match the number of switches in the above switch_map. for (int i = 1; i <= 16; i++) { String key = "output" + String(i); if (x.containsKey("data") && x["data"].containsKey(key.c_str())) { is_target_output = true; output_state = x["data"][key.c_str()]; output_number = i; break; } } if (is_target_output) { auto iterator = switch_map.find(output_number); if (iterator != switch_map.end()) { auto sw = iterator->second; if (output_state) { sw->turn_on(); } else { sw->turn_off(); } } } bool is_target_all_on = false; bool all_on_state = false; if (x.containsKey("data") && x["data"].containsKey("all_on")) { is_target_all_on = true; all_on_state = x["data"]["all_on"]; } if (is_target_all_on) { if (all_on_state) { for(const auto& pair : switch_map) { auto sw = pair.second; sw->turn_on(); } } } bool is_target_all_off = false; bool all_off_state = false; if (x.containsKey("data") && x["data"].containsKey("all_off")) { is_target_all_off = true; all_off_state = x["data"]["all_off"]; } if (is_target_all_off) { if (all_off_state) { for(const auto& pair : switch_map) { auto sw = pair.second; sw->turn_off(); } } } RE: Tuya app by ESPHome in KC868-A16S - admin - 01-02-2024 when you running , whether work well? |
