Advise me on the simplest - Printable Version +- Smart Home Automation Forum (https://www.kincony.com/forum) +-- Forum: Technical Support (https://www.kincony.com/forum/forumdisplay.php?fid=20) +--- Forum: KC868-A16S (https://www.kincony.com/forum/forumdisplay.php?fid=47) +--- Thread: Advise me on the simplest (/showthread.php?tid=4058) |
Advise me on the simplest - Lamri - 01-02-2024 Hello, I am a beginner, and I am struggling to configure my 2 kc868-A16S modules. I have managed to configure the home assistant and integrate Tuya on esphome and it works very well. Unfortunately, I cannot keep the 2 frameworks (home assistant and web page via the IP address). For this, I simply want to keep access to the interface via the IP address so that I can create ifttt and RF scenes, SMS and calls simply and Tuya, but I want voice command either by Alexa or Google Home. Advise me on the simplest, I will buy a module to run Alexa or Google Home to connect with my 2 A16S modules or it is possible to configure Alexa using node red without losing access to the kincony web page via the IP address. Thank you. RE: Advise me on the simplest - admin - 01-02-2024 you can install Node-Red on home assistant, install Alexa or Google home node for Node-Red, then you can use voice control. Because Node-Red can work with home assistant's entities. |
