30 Channel ESP32 energy monitor – KinCony M30 released - Printable Version +- Smart Home Automation Forum (https://www.kincony.com/forum) +-- Forum: Technical Support (https://www.kincony.com/forum/forumdisplay.php?fid=1) +--- Forum: News (https://www.kincony.com/forum/forumdisplay.php?fid=5) +--- Thread: 30 Channel ESP32 energy monitor – KinCony M30 released (/showthread.php?tid=4092) |
30 Channel ESP32 energy monitor – KinCony M30 released - admin - 01-05-2024 We have designed 30 Channel ESP32 energy monitor open source board - M30 (ESP32 30 Channel CT Clamp Energy Monitor) for home automation DIYer. The hardware have 30CH CT Clamp sensor INPUT ports + 3CH ZMPT101B voltage sensor + SD card + 30CH RGB colorful LED for current value. Ethernet+RS485+4G modbus 30CH high-accuracy energy meter ic-BL0910 with CT clamp. it can easy integrate to home assistant by ESPHome. ![]() ![]() ![]() ![]()
RE: 30 Channel ESP32 energy monitor – KinCony M30 released - kkabuu - 03-19-2024 what CT Clamp sensors are recommended for this M30 module RE: 30 Channel ESP32 energy monitor – KinCony M30 released - admin - 03-19-2024 many range types , just chose output 0-1v or 0-50mA signal version. RE: 30 Channel ESP32 energy monitor – KinCony M30 released - jhobson - 05-10-2024 What sampling rate would this platform support, for all the power/current/voltage etc readings ? i.e. ??? samples per AC cycle. ???? AC cycles sampled/second. RE: 30 Channel ESP32 energy monitor – KinCony M30 released - admin - 05-10-2024 you can read > every 500ms cycle. RE: 30 Channel ESP32 energy monitor – KinCony M30 released - WellsGoFar - 07-06-2024 Do you know of any CT clamps for a 200A line that support your 50mA/1V output requirement? |
