I tried to install KC868-A128 but I got an error! - Printable Version
+--- Forum: KC868-A128 (https://www.kincony.com/forum/forumdisplay.php?fid=34)
+--- Thread: I tried to install KC868-A128 but I got an error! (/showthread.php?tid=4093)
I tried to install KC868-A128 but I got an error! - soethu - 01-06-2024
INFO ESPHome 2023.12.5
INFO Reading configuration /config/esphome/a128.yaml...
WARNING GPIO5 is a strapping PIN and should only be used for I/O with care.
Attaching external pullup/down resistors to strapping pins can cause unexpected failures.
See https://esphome.io/guides/faq.html#why-am-i-getting-a-warning-about-strapping-pins
WARNING GPIO15 is a strapping PIN and should only be used for I/O with care.
Failed config
switch.gpio: [source <unicode string>:516]
  Pin 0 is used in multiple places.
  platform: gpio
    pcf8574: pcf8574_hub_out_4
    mode:
      output: True
      input: False
    inverted: True
  disabled_by_default: False
  restore_mode: ALWAYS_OFF
  interlock_wait_time: 0ms
switch.gpio: [source <unicode string>:644]
  platform: gpio
    mode:
      output: True
      input: False
    inverted: True
RE: I tried to install KC868-A128 but I got an error! - admin - 01-06-2024
you can use by this yaml for A128 board: https://www.kincony.com/forum/showthread.php?tid=2114
RE: I tried to install KC868-A128 but I got an error! - soethu - 01-06-2024
(01-06-2024, 04:56 AM)admin Wrote: you can use by this yaml for A128 board: https://www.kincony.com/forum/showthread.php?tid=2114
I used that one but I got an error like that.
your have modified our code. you can use our code directly for a test. your error showed: Pin 0 is used in multiple places. check whether have multi config for Pin0.
RE: I tried to install KC868-A128 but I got an error! - soethu - 01-07-2024
(01-06-2024, 12:18 PM)admin Wrote: your have modified our code.  you can use our code directly for a test.  your error showed:  Pin 0 is used in multiple places.  check whether have multi config for Pin0.
I don't modify you guys code. I just copied and pasted it.
Is there any way to get faster respond. I feel like a kind of bad customer service. I spent a lot of money on you guys devices but customer service taking so long. Plus time different.
Could I have better customer service? Or can you guys installl remotely?
RE: I tried to install KC868-A128 but I got an error! - admin - 01-07-2024
we have already solved your problem by ANYDESK.
RE: I tried to install KC868-A128 but I got an error! - Almhlws - 01-19-2024
I Try to update A128  i get the error
Failed config
  platform: gpio
    mode:
      output: True
      input: False
    inverted: True
  platform: gpio
    mode:
      output: True
      input: False
    inverted: True
RE: I tried to install KC868-A128 but I got an error! - admin - 01-19-2024
you can use our config yaml file for A128 directly: https://www.kincony.com/forum/showthread.php?tid=2114
if also have problem, you can add whatsapp number: +86-15381188302 we remote control your computer to help you.
