when you received the KC868-HxB Controller, how to begin? - Printable Version +- Smart Home Automation Forum (https://www.kincony.com/forum) +-- Forum: Technical Support (https://www.kincony.com/forum/forumdisplay.php?fid=1) +--- Forum: KC868-HxB series Smart Controller (https://www.kincony.com/forum/forumdisplay.php?fid=2) +--- Thread: when you received the KC868-HxB Controller, how to begin? (/showthread.php?tid=41) |
when you received the KC868-HxB Controller, how to begin? - admin - 11-17-2020 we have recorded many videos will help you. 1. How to wire? you need to know the hardware interface and diagram. https://youtu.be/_EbfwEPhMUo 2. Config network setting,maybe you will use ethernet or WiFi.The default setting is "DHCP" by "UDP" work mode. https://youtu.be/X3FSWfuWImg 3. How to install mobile phone app for remote control by cloud server. https://youtu.be/FyPVUguU_h8 4. How to install mobile phone app for local control without internet. https://youtu.be/xdWlEuIxOhA 5. How to use PC software for remote control by cloud server. https://youtu.be/r-DN_30dNrg 6. How to use PC software for local control without internet https://youtu.be/I2twUvE_C4o 7. How to use wall switch panel and wireless remoter for manual control https://youtu.be/Qknel82vPOI 8. How to use voice control by Amazon Alexa speaker https://youtu.be/t62vhuKnsr8 9. How to use voice control by Google home speaker https://youtu.be/ShLsjd22oiU 10. If you already have one user account of mobile phone, but more people want to use.Then you can use grant authorization function to share deivce.(Note: one controller only can add to one phone account) https://youtu.be/j2pb9JPJgZA 11. If you want to relay controller's input port trigger output. Such as input 1 -> relay1 ON,relay2 OFF. step-1: create the scene for relay output actions. https://youtu.be/XzfLEUbYxI0 step-2: set input port trigger with which scene you have created.(Note:when you press relay for ON/OFF,must press the relay name text position when save) https://youtu.be/-JuWCZC39rY 12. If you want to relay controller's input port trigger for a alarm message send to all user. https://youtu.be/-JuWCZC39rY |
