Loxone KC868-A8 - Printable Version +- Smart Home Automation Forum (https://www.kincony.com/forum) +-- Forum: Technical Support (https://www.kincony.com/forum/forumdisplay.php?fid=20) +--- Forum: KC868-A8 (https://www.kincony.com/forum/forumdisplay.php?fid=23) +--- Thread: Loxone KC868-A8 (/showthread.php?tid=4127) Pages:
1
2
Loxone KC868-A8 - StuffMan - 01-10-2024 Any special firmware for Loxone integration with the KC868-A8 board? RE: Loxone KC868-A8 - admin - 01-10-2024 here is config ESPHome component for Loxone: https://github.com/hzkincony/esphome-loxone here is video tour how to do : https://www.youtube.com/watch?v=yj-tDb4gRa0 RE: Loxone KC868-A8 - jviheavy - 02-02-2024 Hello Integration with Loxone? Please could you send the link or explain how do it? Best regards I'm watching the ESPHome integration with Loxone, thanks RE: Loxone KC868-A8 - admin - 02-03-2024 just do as video , the Loxone component made for ESPHome use UDP command. RE: Loxone KC868-A8 - jviheavy - 03-26-2024 Is better and easy if works with your software...with KC v2.2.2 The relay output I can control...but not the inputs and sensors Do you have a template for it? Best regards With the UDP Monitor I find to detect the sensor and state... But I can find the DS18B20 sensor in UDP How I can read the sensor please? RE: Loxone KC868-A8 - admin - 03-27-2024 maybe in furture, we will update KCS firmware to support Loxone by UDP. RE: Loxone KC868-A8 - jviheavy - 03-27-2024 Now works with Loxone by UDP (inputs and outputs), But I can't read the sensor DS18B20 I can read in the KCS Firmware How I can read the sensor by UDP? or Modbus? or TCP? RE: Loxone KC868-A8 - admin - 03-27-2024 yes, Loxone component for ESPHome not added the sensor, maybe in furutre can add that. now you can read sensor by HTTP command, Loxone support integrate by HTTP. RE: Loxone KC868-A8 - jviheavy - 04-05-2024 How I can read by Http? I'm checking the manual and don't find Please could you give me the link http Thanks RE: Loxone KC868-A8 - jviheavy - 04-05-2024 I find it Activate HTTP Server - secret: abcd And then link: http://192.168.1.133/ctrl.cgi?cmd=get_sensors&id=0&value=0&secret=abcd Now I will TRY integrate in Loxone |
