Contactor control - Printable Version +- Smart Home Automation Forum (https://www.kincony.com/forum) +-- Forum: Technical Support (https://www.kincony.com/forum/forumdisplay.php?fid=20) +--- Forum: KC868-A4 (https://www.kincony.com/forum/forumdisplay.php?fid=21) +--- Thread: Contactor control (/showthread.php?tid=4169) |
Contactor control - Fekry - 01-14-2024 Hello Can i use the relay to signal contactor to turn on or off ? Also can the relays work as a dry contact ? How long wire can i use for tempreature sensor and for water level sensor ? Can it be 30 meters long ? Thank you RE: Contactor control - admin - 01-14-2024 sure, our relay controller relay is dry contactor, it have not connect with any power. what temperature sensor you will use ? DS18B20? 30 meter is too long, maybe you need to use thick wire, test with 30 meter, i am not sure whether can work stable. |
