KC 868 A4S Home assistant help - Printable Version +- Smart Home Automation Forum (https://www.kincony.com/forum) +-- Forum: Technical Support (https://www.kincony.com/forum/forumdisplay.php?fid=1) +--- Forum: News (https://www.kincony.com/forum/forumdisplay.php?fid=5) +--- Thread: KC 868 A4S Home assistant help (/showthread.php?tid=4275) |
KC 868 A4S Home assistant help - hocine86 - 02-11-2024 I have a kincony KC868 A4s board and I want to program a smart home using home I have a kincony KC868 A4s board and I want to program a smart home using home assistant 1- DHT22 temperature and humidity sensor 2-door sensor 3- BIR sensor 4- water level So that relay 1 control by DHT22 and relay2 control by water level Door sensor send notification while door open BIR send notification When anyone moves around Please send me the configuration file of home assistant Thanks and regards RE: KC 868 A4S Home assistant help - admin - 02-11-2024 this is A4S typical config yaml: https://www.kincony.com/forum/showthread.php?tid=2618 it have used INPUT and OUTPUT ports. how to add DHT22, you can use free GPIO connect with DHT22, config yaml as here: https://esphome.io/components/sensor/dht.html about "notification" you can set in home assistant AUTOMATIN call service. |
