Kc868-A128 interlock - Printable Version +- Smart Home Automation Forum (https://www.kincony.com/forum) +-- Forum: Technical Support (https://www.kincony.com/forum/forumdisplay.php?fid=1) +--- Forum: KC868-HxB series Smart Controller (https://www.kincony.com/forum/forumdisplay.php?fid=2) +--- Thread: Kc868-A128 interlock (/showthread.php?tid=4635) |
Kc868-A128 interlock - ahmedwizza1 - 02-24-2024 Hello ingneer I have KC868-A128 esp I used esp protocol But we need to make interlock fo curtains and shutters.. Can you give me the code for this operation To add it to me esp config in home assistant ??????? RE: Kc868-A128 interlock - admin - 02-24-2024 do you use ESPHome or KCS firmware? if you use ESPHome, just config interlock in yaml, for example: - platform: gpio name: "curtain2-up" id: relay7 interlock: [relay8] pin: pcf8574: pcf8574_hub_out_1 number: 6 mode: OUTPUT inverted: true - platform: gpio name: "curtain2-down" id: relay8 interlock: [relay7] pin: pcf8574: pcf8574_hub_out_1 number: 7 mode: OUTPUT inverted: true |
