KC868-A4 static IP address - Printable Version +- Smart Home Automation Forum (https://www.kincony.com/forum) +-- Forum: Technical Support (https://www.kincony.com/forum/forumdisplay.php?fid=20) +--- Forum: KC868-A4 (https://www.kincony.com/forum/forumdisplay.php?fid=21) +--- Thread: KC868-A4 static IP address (/showthread.php?tid=4842) |
KC868-A4 static IP address - Zoltansz1986 - 03-03-2024 Hello, In my house I integrated the KC868 A4, A8 and A16 controllers (with KCS firmware) into the TapHome system. I used the Http Server for the connection. The static ip address is important here. In the case of A8 and A16, the static ip can be set in the KCS, but in the A4 it is not available, as it only has wifi. Is there a possibility for this? I ask for your help. Regards, Zoltán RE: KC868-A4 static IP address - admin - 03-03-2024 now wifi only work with DHCP in KCS. do you use mqtt integrate to your own system? RE: KC868-A4 static IP address - Zoltansz1986 - 03-07-2024 Hi Admin! Thanks for your feedback! I don't use MQTT integration in my own system, but I can run MQTT broker in my smart-home server. You think that I can use KC868-A4 as a client and there will be no problem that it works via dhcp? Best regards, Zoltán Szőke RE: KC868-A4 static IP address - admin - 03-07-2024 you can config by ESPHome, use static IP work with your mqtt broker. here is ESPHome mqtt online guide: https://esphome.io/components/mqtt.html |
