A8 lost network connection via LAN - Printable Version +- Smart Home Automation Forum (https://www.kincony.com/forum) +-- Forum: Technical Support (https://www.kincony.com/forum/forumdisplay.php?fid=20) +--- Forum: KC868-A8 (https://www.kincony.com/forum/forumdisplay.php?fid=23) +--- Thread: A8 lost network connection via LAN (/showthread.php?tid=4927) |
A8 lost network connection via LAN - a.demenev@limeup.ru - 03-04-2024 Hi all! i integrate A8 to my ventilation system, it works fine, BUT!!!! A8 lost network connection via LAN every 10-40 minutes... after restart connection establishing in few seconds. https://youtube.com/shorts/jyNo9KttSPs?si=RqN1gTOHdtjRSwSU Any ideas? PS: yes, i know, i need some switches in this construction - they a planned and will be installed soon RE: A8 lost network connection via LAN - a.demenev@limeup.ru - 03-04-2024 (03-04-2024, 06:02 PM)a.demenev@limeup.ru Wrote: Hi all! Update: software is KCS v2.1.9 I start "ping" from my laptop - A8 replay around 3 hour, but than "dies"((( In same time A16S with KCS v2.2.2 works fine - i did not find no one "connection lost" for this time RE: A8 lost network connection via LAN - admin - 03-04-2024 what power supply you used for A8? in your video there is RED cable connect to i2c bus extender, what's this use for? RE: A8 lost network connection via LAN - a.demenev@limeup.ru - 03-05-2024 (03-04-2024, 10:31 PM)admin Wrote: what power supply you used for A8? Hi! power supply is 12v 5A with 2 battery Red cable used to power on another ESP8266. Yesterday i remove this cable and power on ESP8266 by usb - with same result - connection lost... Next i find KCS v2.2.2 and install it - so, it work more than 6 hours now, and connection is OK! I will observe, but i hope the problem is solved. Thank You! RE: A8 lost network connection via LAN - admin - 03-05-2024 can you test with another power supply. RE: A8 lost network connection via LAN - a.demenev@limeup.ru - 03-05-2024 (03-05-2024, 05:22 AM)a.demenev@limeup.ru Wrote:ok, i will try another power supply today later(03-04-2024, 10:31 PM)admin Wrote: what power supply you used for A8? now A8 is failed again ((( 192.168.7.11 - A8 192.168.7.12 - A16S RE: A8 lost network connection via LAN - admin - 03-05-2024 do you buy A8 from KinCony official store? if YES, please send us your order number. RE: A8 lost network connection via LAN - a.demenev@limeup.ru - 03-05-2024 (03-05-2024, 12:02 PM)admin Wrote: do you buy A8 from KinCony official store? if YES, please send us your order number. Unfortunately, i bought it from another seller... in official store i bought another stuff is it really critical? RE: A8 lost network connection via LAN - admin - 03-05-2024 can you test with wifi whether work well, not use ethernet. RE: A8 lost network connection via LAN - a.demenev@limeup.ru - 03-07-2024 (03-05-2024, 10:40 PM)admin Wrote: can you test with wifi whether work well, not use ethernet. Hi! i try to use wi-fi - result is same. it works 1-4 hours and than lost connection. |
