Time display issue in the KC868-A index page - Printable Version +- Smart Home Automation Forum (https://www.kincony.com/forum) +-- Forum: Technical Support (https://www.kincony.com/forum/forumdisplay.php?fid=20) +--- Forum: KC868-A8 (https://www.kincony.com/forum/forumdisplay.php?fid=23) +--- Thread: Time display issue in the KC868-A index page (/showthread.php?tid=5269) |
Time display issue in the KC868-A index page - HA7CQ - 03-18-2024 Greetings! We have programmed many IFTT timer commands. It is important to have the correct time settings in our project. (We control the movement of Bells ) NTP time service works fine, but the board time displayed on the index page is incorrect (displayed ~ Central American). The KC868_A8 panel working in the true timezone (UTC+1 in our country).It's causing me trouble because I thought the NTP clock setting process was wrong. I attached the display capture. Can we correct it? RE: Time display issue in the KC868-A index page - admin - 03-19-2024 It's really strange, some people have problems, some people don't have problems. i think you can change your UTC zone +7, just let your board's time as same as your computer's time. then you can use IFTTT command. UTC zone is not important. RE: Time display issue in the KC868-A index page - AlexOliveira - 07-05-2024 Hello. I'm new here... I have a KC868-A16 board with Tasmota installed... The inputs and outputs are already in operation, however I would like to add external temperature and humidity sensors....but I can't find the DHT11 or AM2301 sensors on the list... Is it possible to add? As? Thanks RE: Time display issue in the KC868-A index page - admin - 07-05-2024 you can create a tsmota firmware, enable these sensors. https://www.kincony.com/forum/showthread.php?tid=5432 |
