Alexa can't find devices - Printable Version +- Smart Home Automation Forum (https://www.kincony.com/forum) +-- Forum: Technical Support (https://www.kincony.com/forum/forumdisplay.php?fid=20) +--- Forum: KC868-A8 (https://www.kincony.com/forum/forumdisplay.php?fid=23) +--- Thread: Alexa can't find devices (/showthread.php?tid=5414) |
Alexa can't find devices - Rodrigo nunes - 03-26-2024 Good afternoon everyone, I'm having difficulty configuring the board for Alexa to identify the channels, I'm using Tasmota firmware, I'll list what happens. 1- when I install the firmware and do all the steps, Alexa finds the 8 channels 2- this same board that Alexa found the channels, if I connect via network cable to another router other than the one previously configured, she doesn't find it channels 3 - I noticed that it generates a valid IP, so much so that I can access the tasmota settings. 4- I also noticed that it keeps trying to connect to the previously configured network. 5- For example, if you configure it on Wi-Fi and lose the signal, even via network cable, the channels will be offline My question would be the following, can I configure the board in my workshop and get home and connect via network cable and search for the device on Alexa? RE: Alexa can't find devices - admin - 03-27-2024 the easiest way use your KC868-A8 is order a tuya license, use by KCS firmware. add another one Tuya adapter is ok. without any program code. tasmota some times is not stable. |
