KC686-A4 0-10 ->PWM - Printable Version +- Smart Home Automation Forum (https://www.kincony.com/forum) +-- Forum: Technical Support (https://www.kincony.com/forum/forumdisplay.php?fid=20) +--- Forum: KC868-A4 (https://www.kincony.com/forum/forumdisplay.php?fid=21) +--- Thread: KC686-A4 0-10 ->PWM (/showthread.php?tid=5416) |
KC686-A4 0-10 ->PWM - Yocee - 03-27-2024 Hello! Is it possible to use the 0-10v output as a pwm output? I want to control a heating pump with it. The firmware would be ESPhome. I am attaching the pump PWM signal data. esphome: name: pump platform: ESP32 wifi: ssid: "xxx" password: "xxx" # Enable logging logger: # Enable Home Assistant API api: password: "xxx" ota: password: "xxx" output: - platform: ledc pin: GPIO26 frequency: 100 Hz id: pump_pwm fan: - platform: speed output: pump_pwm name: "pump" RE: KC686-A4 0-10 ->PWM - admin - 03-27-2024 you can try, i have not tested, A4S have PWM output port. |
