KC868-A4 DIGITAL I/O - Printable Version +- Smart Home Automation Forum (https://www.kincony.com/forum) +-- Forum: Technical Support (https://www.kincony.com/forum/forumdisplay.php?fid=20) +--- Forum: KC868-A4 (https://www.kincony.com/forum/forumdisplay.php?fid=21) +--- Thread: KC868-A4 DIGITAL I/O (/showthread.php?tid=5442) |
KC868-A4 DIGITAL I/O - franco.demei@gmail.com - 04-02-2024 Hi all, I'm trying to program the KC868-A4 to activate the relay, as long as the corresponding digital input is activated. When I release the button the corresponding relay should deactivates. With the code I wrote, when I close the digital input the relevant relay turns on. But when I open the digital imput, The relay remains on. Can some one tell me where is a mistake ? Below the code in use. Thank You #define Relay1 2 #define Relay2 15 #define Relay3 5 #define Relay4 4 #define Key1 36 #define Key2 39 #define Key3 27 #define Key4 14 int KEY_NUM1; // KEY_1 value int KEY_NUM2; // KEY_2 value int KEY_NUM3; // KEY_3 value int KEY_NUM4; // KEY_4 value void setup() { pinMode(Relay1, OUTPUT); // Relay1 IO2 pinMode(Relay2, OUTPUT); // Relay2 IO15 pinMode(Relay3, OUTPUT); // Relay1 IO5 pinMode(Relay4, OUTPUT); // Relay1 IO4 pinMode(Key1, INPUT); // Dig. Input1 IO36 pinMode(Key2, INPUT); // Dig. Input2 IO39 pinMode(Key3, INPUT); // Dig. Input3 IO27 pinMode(Key4, INPUT); // Dig. Input4 IO14 } void loop() { ScanKey1(); // Call function to scan Key1 ScanKey2(); // Call function to scan Key2 ScanKey3(); // Call function to scan Key3 ScanKey4(); // Call function to scan Key4 } void ScanKey1() { KEY_NUM1 = 0; // Check if Key1 is pressed if (digitalRead(Key1) == LOW) { // Key1 Pressed delay(20); // Wait for button debounce if (digitalRead(Key1) == LOW) { KEY_NUM1 = 1; // Toggle relay1 state until Key1 is released while (digitalRead(Key1) == LOW) { digitalWrite(Relay1, !digitalRead(Relay1)); // Toggle relay1 state delay(100); // Adjust delay as needed to control toggle speed } } } } void ScanKey2() { KEY_NUM2 = 0; // Check if Key2 is pressed if (digitalRead(Key2) == LOW) { // Key2 Pressed delay(20); if (digitalRead(Key2) == LOW) { KEY_NUM2 = 1; // Toggle relay2 state until Key2 is released while (digitalRead(Key2) == LOW) { digitalWrite(Relay2, !digitalRead(Relay2)); // Toggle relay2 state delay(100); // Adjust delay as needed to control toggle speed } } } } void ScanKey3() { KEY_NUM3 = 0; // Check if Key3 is pressed if (digitalRead(Key3) == LOW) { // Key3 Pressed delay(20); if (digitalRead(Key3) == LOW) { KEY_NUM3 = 1; // Toggle relay3 state until Key3 is released while (digitalRead(Key3) == LOW) { digitalWrite(Relay3,HIGH); // Toggle relay3 state delay(100); // Adjust delay as needed to control toggle speed } } } } void ScanKey4() { KEY_NUM3 = 0; // Check if Key4 is pressed if (digitalRead(Key4) == LOW) { // Key4 Pressed delay(20); if (digitalRead(Key4) == LOW) { KEY_NUM3 = 1; // Toggle relay4 state until Key4 is released while (digitalRead(Key4) == LOW) { digitalWrite(Relay4,HIGH); // Toggle relay4 state delay(100); // Adjust delay as needed to control toggle speed } } } } RE: KC868-A4 DIGITAL I/O - admin - 04-02-2024 your code function is when digital input trigger, Toggle relay. you can replace this code: digitalWrite(Relay1, !digitalRead(Relay1)); use if .... else ... for ON/OFF relay. RE: KC868-A4 DIGITAL I/O - franco.demei@gmail.com - 04-03-2024 (04-02-2024, 09:52 PM)admin Wrote: your code function is when digital input trigger, Toggle relay. Thank you Sir, SOLVED in this way : void ScanKey1() { KEY_NUM1 = 1; // Key1 unpressed if (digitalRead(Key1) == LOW) { // Key1 Pressed delay(20); if (digitalRead(Key1) == LOW) { KEY_NUM1 = 0; // if digitalRead(Key1 == low) digitalWrite(Relay1, HIGH); // Relay1 is Turned ON } else { // if Key1 is turned OFF (Key4 open) digitalWrite(Relay1, LOW); // Rela1 is turned OFF } } } RE: KC868-A4 DIGITAL I/O - admin - 04-03-2024 ok, good. |
