Screws to lock the board on the back of the box - Printable Version +- Smart Home Automation Forum (https://www.kincony.com/forum) +-- Forum: Technical Support (https://www.kincony.com/forum/forumdisplay.php?fid=20) +--- Forum: KC868-A16 (https://www.kincony.com/forum/forumdisplay.php?fid=25) +--- Thread: Screws to lock the board on the back of the box (/showthread.php?tid=5643) |
Screws to lock the board on the back of the box - Domdsq - 04-25-2024 Hi everyone, I need to know which screws to buy to be able to fix the card directly to the back of the box (as indicated in the photo). I need to remove the front part of the box because in the European control panel the default box does not fit, it does not allow it to be closed correctly, so I have to find the correct screws to be able to do it. I attach photos. Thank you
RE: Screws to lock the board on the back of the box - admin - 04-25-2024 tomorrow take screw size photo to you. RE: Screws to lock the board on the back of the box - Domdsq - 04-29-2024 (04-25-2024, 10:34 AM)admin Wrote: tomorrow take screw size photo to you. Hi! Were you able to find the screw sizes? Thank you RE: Screws to lock the board on the back of the box - admin - 04-29-2024 sorry, these days during China holidays, when we begin work, will take photo to you. RE: Screws to lock the board on the back of the box - admin - 05-02-2024 the screw size is 2.6*6 you can see the photo. RE: Screws to lock the board on the back of the box - Domdsq - 05-02-2024 Perfect, thank you! RE: Screws to lock the board on the back of the box - Domdsq - 05-13-2024 I'm returning to this post to ask one additional thing. Is it possible to buy the metal cover for A16 board? In the photo it appears to be more compact, this may facilitate installation in an EU electrical panel. Thanks, I attach photo.
RE: Screws to lock the board on the back of the box - Domdsq - 06-06-2024 (05-13-2024, 11:25 AM)Domdsq Wrote: I'm returning to this post to ask one additional thing. Is it possible to buy the metal cover for A16 board? In the photo it appears to be more compact, this may facilitate installation in an EU electrical panel. Thanks, I attach photo. Please, is it possible to have an answer? If the product is not on sale here, you can find out where to buy it or have the measurements to be able to 3D print it. A thousand thanks RE: Screws to lock the board on the back of the box - admin - 06-06-2024 sorry, metal box version not in stock now. how many pcs do you want? |
