KC868-A4 Bluetooth momentary Switch - Printable Version +- Smart Home Automation Forum (https://www.kincony.com/forum) +-- Forum: Technical Support (https://www.kincony.com/forum/forumdisplay.php?fid=20) +--- Forum: KC868-A4 (https://www.kincony.com/forum/forumdisplay.php?fid=21) +--- Thread: KC868-A4 Bluetooth momentary Switch (/showthread.php?tid=5652) |
KC868-A4 Bluetooth momentary Switch - franco.demei@gmail.com - 04-27-2024 I'm trying to program four momentary switch via bluetooth commands. I don't understand why I can't enable "Relay3". To compile KC868-A4 code I'm using "Arduino IDE". To program Android code "MIT App Inventory" . Here is the codes I Used. Can some one help me to understand where is a mistake ? Tank You. AI Code Arduino IDE Code: #include "BluetoothSerial.h" BluetoothSerial SerialBT; // RX | TX int Relay1 = 2; int Relay2 = 5; int Relay3 = 15; int Relay4 = 4; void setup() { pinMode(Relay1, OUTPUT); pinMode(Relay2, OUTPUT); pinMode(Relay3, OUTPUT); pinMode(Relay4, OUTPUT); Serial.begin(19200); // Serial monitor SerialBT.begin(19200); // Bluetooth serial communication Serial.println("Bluetooth Control for KC868-A4 Relays"); } void loop() { if (SerialBT.available()) { char command = SerialBT.read(); // Command format: '1' to '4' for relays 1 to 4 if (command >= '1' && command <= '4') { int relay = command - '1' + 2; // Calculate the relay control pin digitalWrite(relay, !digitalRead(relay)); Serial.print("Relay "); Serial.print(command); Serial.print(" is "); Serial.println(digitalRead(relay) ? "ON" : "OFF"); } } } RE: KC868-A4 Bluetooth momentary Switch - admin - 04-28-2024 this is KC868-A4 relay control by bluetooth arduino demo code, you can test it: https://www.kincony.com/forum/showthread.php?tid=1647 RE: KC868-A4 Bluetooth momentary Switch - franco.demei@gmail.com - 05-06-2024 (04-28-2024, 12:50 AM)admin Wrote: this is KC868-A4 relay control by bluetooth arduino demo code, you can test it: https://www.kincony.com/forum/showthread.php?tid=1647 I solved in this way: Code: #include "BluetoothSerial.h" RE: KC868-A4 Bluetooth momentary Switch - admin - 05-06-2024 ok, good. |
